| Yanmar 4JH-TE exaust system sizing Question. I have a Yanmar 4JH-TE. Exhaust outlet from mixing elbow is 3" Dia. The muffler and exhaust hose that came with the engine has inlet/outlet size of 1-5/8". Somewhere along the line there must have been a reducer of some sort but that wasn't included. I have the service manual for the engine but there's no mention of minimum exhaust size requirements. I don't know much about diesel engines, well actually at this point I know nothing about them, but if they breath better, larger exhaust, they should run better no? Can I go down to 2" all the way back (approx 12' run through water lock, muffler & gooseneck)? That should be better for the engine or should I keep it 3" all the way back?
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| 2 inch seems good to me, assuming that it is an almost straight tube gently sloping down to the muffler. How do you plan to connect it to the 3" exhaust? |
| Get an installation manual for the engine. You can probably download it. It has everything you need to know.
__________________ Gonzo |
| I do have the Yanmar installation manual and the rule is never ever go less than the engine outlet. This is a turbo engine and 2 inch is ridiculously small, if its a power boat use nothing as a silencer or dump bucket. I have the 6Lp and use 100 mm all the way out. Its not noisy being turbo. |
| Thnx Fella's. I have the service manual but it says nothing about exhaust hose dia. or back pressure etc.. Since I have to buy all new exhaust components anyways I'm going to go all 3". I don't know exactly where the smaller muffler & hose came from but I'm doubting it was with this engine.
| Yanmar - How long should it take for oil pressure to come up from a cold start? | Frosty | Diesel Engines | 242 | 05-11-2010 09:32 AM |
| yanmar 315 | the black devil | Sterndrives | 0 | 10-19-2007 04:51 PM |
| Cummins vs Yanmar | vjb | Diesel Engines | 67 | 03-27-2007 06:56 AM |
| Yanmar YSE-8 | sjo hest | Diesel Engines | 2 | 02-23-2007 06:36 PM |
| Yanmar GM Series 1GM10E | Robert Miller | Sailboats | 4 | 07-21-2004 08:31 AM |
