Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 03-16-2008, 02:10 PM
erwin.tarr erwin.tarr is offline
Rep: 29 Posts: 28
Yanmar 3GM30F Problems (HELP!)
Hello all,
I am having an issue with my Yanmar 3GM30F that hopefully one of you can help with.
I went to my boat on Friday and fired up the engine in preparation of a day on the water yesterday. The engine ran great and I ran it long enough to warm it up then shut it down. I went back to the slip with my family yesterday and the engine acted completely differently.
First off, it was hard to get started. Once it fired up, there was a popping noise coming from the air intake every time the number one cylinder fired (almost like a backfire?). I opened and closed each of the decompression levers one at a time and when I opened the number one cylindar, the popping stopped. Do you think I have an intake valve on the number one cylindar sticking. Are you concerned with a slight film on the surface of the antifreeze when I open the cover? Also, when I started it yesterday, the plastic antifreeze reservoir overflowed hard enough to knock the lid off.
That started my mind in the direction of a head gasket allowing compression into the water jacket and compressing the fluid in the reservoir, thus blowing the lid off the reservoir. Would this cause a popping noise at the air intake? Am I thinking too much into this?
I bought the boat used so I don't know the history of the engine but it has ran like a champ since I got it and did fine during a 200 mile on-engine run from Miami.
Could it be something else? What is the fix?
Also, what grade/brand of motor oil do you suggest? I am not sure what API Service "C" is. I used what the manual suggested (30 weight).
Any advise would be appreciated, I want to go sailing.
Ray Tarr
Patrick AFB, Fl
1963 Allied Seawind, Crackertail
Hull # 25
Old 03-18-2008, 12:54 PM
kenJ kenJ is offline
Rep: 56 Posts: 323
Valves don't normally stick on their own unless they are somehow bent. My guess would be a bad head gasket or a cracked head. Check for water in the oil, it is a good indicator of a bad head gasekt. A compression test is also a good troubleshooting aid. Did you confirm that you had cooling water coming out the exhaust when you warmed it up on Friday? Overheat is a very common cause of head/gasket problems.
Old 05-27-2008, 05:53 AM
Psychobob Psychobob is offline
Rep: 10 Posts: 3
You guessed it.
The problem is most likely a blown head gasket. This scenario suits all your symptoms.
yanmar 315 the black devil Sterndrives 0 10-19-2007 04:51 PM
Cummins vs Yanmar vjb Diesel Engines 67 03-27-2007 06:56 AM
Yanmar YSE-8 sjo hest Diesel Engines 2 02-23-2007 06:36 PM
yanmar 6lp-stzp 315hp hilux38 Propulsion 3 12-07-2004 03:32 AM
Yanmar GM Series 1GM10E Robert Miller Sailboats 4 07-21-2004 08:31 AM
