Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 09-29-2011, 09:45 PM
tropicalbuilder tropicalbuilder is offline
Rep: 38 Posts: 32
yanmar 100hp idle rpm
what is the best idle rpm for a yanmar 100hp
Old 09-30-2011, 04:36 AM
Rep: 670 Posts: 2,457
Dont know..trial and error. Remember that when you start your engine the alternators will load up and drag your rpm down.
Old 09-30-2011, 12:42 PM
BKay BKay is offline
Rep: 20 Posts: 13
Tropicalbuilder - I have a Yanmar 110hp 4JH4-HTE. I don't recall the number off the top of my head, but I'm going out to the boat tomorrow and I'll confirm from my notes. I had to adjust idle on my engine last year and I got the factory acceptable idle range from Mack Boring. Let me pull my notes up and I'll get you the answer as it applies to my engine.
Old 09-30-2011, 01:07 PM
Rep: 20 Posts: 13
OK, found my notes. My engine was set to idle at 800 RPM and Mack Boring said the specs allowed for plus or minus 25 RPMs. Not sure what engine you have, but that was for a 4JH4-HTE. Good luck.
Old 09-30-2011, 09:35 PM
Rep: 38 Posts: 32
4jh3-hte and the manual says the idle should be 700 +-25 ...
but i feel that a little low, at the moment i set it on 800 and sounds good ...
thanks
Idle problem mnwiley Gas Engines 3 05-27-2010 08:48 AM
Overheating at Idle Holden441 Inboards 7 03-03-2008 11:11 AM
100hp. Merc on 14ft. semi-v? haworth1967 Outboards 19 01-07-2007 11:16 PM
charging problem in evenrude 100hp (66 model) tojulio Outboards 0 07-05-2006 10:10 AM
overheats at idle capslovak Propulsion 0 04-24-2006 02:45 PM
