| V6 53 detriot fuel problem i have a pair of these loverly old things in my 1964 dutch gentlemans motor boat . i have stript them down twice now and am still getting what looks like deisel comeing out with the water and smoke ???? one engine only . i am at my whitts end can any one help ?? Thanks |
| is there any fuel in the jacket water(fresh_ |
| First thing, get and engine oil sample and get it checked. |
| ok I,m thinking, usually injecter sleeves leak which either have holes or bad seats, leak overr to jacket I,m not a Detroit expert, but on any make I can noy think how fuel can pass to Raw water, you sure its not oil? Cos oil can, from leaking cooler or many ways In fact casting my mind back I,m sure its lube oil |
| wrong, he has oil in water not water in oil |
| You will have more oil pressure then water pressure when running. |
| fuel in exhaust water this does appear to be fuel as when i check dip stick oil level has not changed ? some has suggested a faulty injector spilling to much fuel into cylinder then being ejected with exhaust stroke ? Would that be likely ? |
| does not matter, I have seen huge gears empty through leaking coolers I was FIELD SERVICEMAN fot Cummins Eng Co in early 1970,s before taking up boat and yachtbuilding, and I used to come across this sort of this quite often |
| Does the engine miss when running? You can pull the valve covers and short out one injector at a time and find the bad one. |
| detroit 6v53 John, You are making smoke right? black or white? both mean unburned fuel which will show up in exhaust,check rack adjustment,injector height,also the injectors themselves,have they been o/hauled ,injector height needs special tool ......good luck |
| fuel in exhaust water i have fitted brand new dd injectors and they are all timed up correctly using the correct tool ?? I have checked the rack taht many times - i hate it !!!! what is a cracked cup - lazeyjack? |
| boatdiesel.com Hoi John, Some people on this forum have great knowlage about diesels and i would not want to offend anyone trying to anwser your questions here but perhaps you can post your problem at http://boatdiesel.com/index.cfm it's very active and they even have a dedicated Detroit 53 series section. |
| have pressure tested cooler and no problems there ? any more ideas lads ? i will have a look at the injector cups as they may be damaged thanks |
| Fuel tanks | Ian Farnell | Materials | 35 | 12-04-2006 10:31 AM |
| Fuel consumtion and alternative fuel | StianM | Open Discussion: All Things Boats & Boating | 22 | 05-11-2006 08:56 PM |
| Fuel Consumption | Poida | Boat Design | 27 | 05-10-2006 07:15 AM |
| Fuel Tank | man5 | Fiberglass and Composite Boat Building | 35 | 05-05-2006 07:28 AM |
| Detriot Diesel 6v92 reliability & problem experiences | Guest | Powerboats | 1 | 01-01-2004 09:56 PM |
