| detroit 6v53 John....I agree with seaspark on this matter,the boys on boat diesel really know their stuff,you can post a question there without being a member .I own a 71 series detroit myself ,great engines ,i'm sure you will find the answer good luck .........cheers |
| John, Recently one of my 6V-53's took a slug of water up the exhaust. Unknowingly I hit the starter before air box drained out. The result was a rod bent just enough to prevent the piston from traveling far enough to fire. this caused a cloud of white smoke and fuel sheen at all engine speeds. Also, these engines do not like to idle and will put raw fuel into exhaust at RPM under 800. According to DETROIT mechanics this is normal for these engines. Swimpy |
| john u have 3 options injectors, pump timing or compression check em all in reverse order its most likely injector nozzle wear |
| Check for broken oil rings when you disassemble the engine. They are very easy to break when installing and would let crankcase oil go out the exhaust and water. Even if it looks like you're not losing oil on the dipstick a slight amount being sent out the exhaust might give you what you've got and not be enough to easily see on a dipstick. |
| Fuel tanks | Ian Farnell | Materials | 35 | 12-04-2006 10:31 AM |
| Fuel consumtion and alternative fuel | StianM | Open Discussion: All Things Boats & Boating | 22 | 05-11-2006 08:56 PM |
| Fuel Consumption | Poida | Boat Design | 27 | 05-10-2006 07:15 AM |
| Fuel Tank | man5 | Fiberglass and Composite Boat Building | 35 | 05-05-2006 07:28 AM |
| Detriot Diesel 6v92 reliability & problem experiences | Guest | Powerboats | 1 | 01-01-2004 09:56 PM |
