Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 07-30-2009, 04:56 PM
B33RND's Avatar
B33RND B33RND is offline
Rep: 10 Posts: 23
Two engine's on one keel/box cooler?
Hello,
Does some of you have experience in attaching two engines to one single keel/box cooler? It is not required to have them running simultaneously. Perhaps somebody has a diagram?
Thanks in advance for any reply.
Berend
Old 08-09-2009, 03:09 PM
powerabout powerabout is offline
Rep: 432 Posts: 1,358
with valves to isolate one from the other and they are at the same level / height as in radiator caps and are similar size engine so the on engine pumps are similar.
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 09-13-2009, 07:36 PM
singleprop singleprop is offline
Rep: 10 Posts: 48
Box cooler partition
Some box coolers can be specified with 2 or 3 partitions, i.e a section for each user (engine, air conditioner, genset gear box etc), where each section is sized after the load, and each section hads its own inlet and outlet.
Try Weka and Klima.
Singleprop
Box Keel Brands01 Boat Design 62 08-10-2009 12:32 PM
Box? keel sailing hull lewisboats Boat Design 30 10-01-2007 04:44 PM
keel cooler for aircondition, generator, and engine dennis morris Boat Design 5 05-09-2007 03:37 PM
Taping into keel cooler? ted655 Diesel Engines 2 10-31-2006 02:05 PM
glassing the inside of a keel box.... capt'n ron Wooden Boat Building and Restoration 0 08-08-2005 09:29 PM
