Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 09-06-2006, 08:06 PM
goodidea28 goodidea28 is offline
Rep: 10 Posts: 5
Twin inboard gas to single diesel conversion
Thinking about converting my 28 seabird sportfish (twin 225 cryslers) to a single diesel.Has any one done this or could recomend what type of horsepower would be compatable in a diesel?The boat weighs about 10,000lbs and cruises at around 20kts.The chryslers are coupled to v-drives, if changed to a diesel should I use a single V-drive to keep the weight in the rear or move the engine toward the front?I would assume a single diesel strait 6 would weigh as much as the two 318 chryslers.Any advise would be appreciated, thanks.
-Glenn Burgess
Old 09-07-2006, 12:48 AM
StianM's Avatar
StianM StianM is offline
Rep: 114 Posts: 577
You can find aluminium alloy diesels. steyr make them and I think they would be light compared to some old chryslers.
You could also convert a turbo diesel from a car with aluminium block.
I don't think you wil have problems finding a aluminium turbo diesel with the same weight to power ration as a normaly aspirated gasoline engine.
Twin V6 to single diesel conversion burt2 Propulsion 21 02-01-2011 08:00 PM
Question ; Single Inboard Conversion To Twin RYANPO Powerboats 10 11-29-2006 11:52 AM
Single Inboard To Twin Outboards RYANPO Boat Design 7 07-20-2006 06:07 PM
Twin diesel / generator / single shaft prop setup SeaSpark Propulsion 2 04-22-2006 03:47 PM
Twin 4 Cylinders to Twin V8s Conversion Help Tom Cahoone Boatbuilding 1 08-11-2004 10:29 AM
