Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 12-03-2010, 06:08 AM
Jonny88 Jonny88 is offline
Rep: 10 Posts: 14
Turbocharging a diesel engine?
Hi folks,
I'm looking to find out as much as I can about the turbocharging of diesel engines. Looking more at large installations for ships and things, but any theory anyone might be able to pass on would be great!
Thanks in advance.
Jonny.
Old 12-03-2010, 11:52 AM
Rep: 1493 Posts: 7,447
Do you plan on turbocharging an existing engine. It will need different pistons and rings, Valves and guides may not work, lower compression, fuel injection pump and injectors.
Old 12-03-2010, 12:05 PM
Rep: 10 Posts: 14
Not planning to do anything to anything.
Need to learn about it for a bit of undergraduate work I'm doing and thought a boating forum might be a good place to start. I already have a pretty good knowledge but is pretty difficult to come across anything half decent on the internet so thought I'd ask.
Cheers.
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Why?
If it's general interest simply Google it but if you have any specific question then ask.
-Tom
Old 12-03-2010, 12:55 PM
Check out manufacturer's websites. They will give you all the specifications and technical data.
Old 12-06-2010, 02:22 PM
JosephT's Avatar
JosephT JosephT is offline
Rep: 113 Posts: 170
Turbo charging any engine will put a heavier load on the engine. You should check with the engine manufacturer or a highly experienced engine shop before considering it. If the block, pistons, rings, etc. can take this additional load then the next step is to consider what type of turbo charger to install.
Regards,
Joe
Old 12-06-2010, 09:18 PM
Mariner
...and how many pounds (Newtons) of boost to use...
-Tom
P.S. Or is it kilo-pascals not Newtons...
Old 12-16-2010, 04:17 PM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
What are the ups and downs of running a turbo diesel at 50% load or less over extended periods? Would Would the removal of the turbo be a good option?
Easy Rider
Old 12-17-2010, 06:32 AM
Rep: 756 Posts: 3,328
"Would Would the removal of the turbo be a good option?"
On many engines the block, turbo or non turbo is the same but the compression ratio is lower on the turbo engines.It might run really poorly with out the turbo.
Turboed engines may also have an intercooler of some type.
On some Perkins I have seen the turbo kept , and the rotten really expensive intercooler simply tossed.
Probably some loss of power and efficiency , but on a 8K trawler , who would miss it?
FF
Old 12-17-2010, 01:07 PM
Easy Rider's Avatar
Rep: 694 Posts: 670
Fred,
I feel really stupid ..forgot about the compression ratio. There must be a point down at the lower end (rpm) where the boost is insufficent to bring the BMEP up the NA engine level. So it would seem a turbo engine would be actually less efficent than a NA engine at low speeds .....but what low speeds.
Easy
Old 12-17-2010, 02:19 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
Easy, unless your diesel and turbo are really old (mechanical) don't remove or put on. I have had race cars and the current electronic systems totally run engines and turbos so you have to have a race mechanic who can re-program the system computers for air pressure, volume, fuel input etc. and it's way over my head. I've watched them do it on my cars and they have added 150 hp playing with a computer. If you do not know how to do this you could blow every thing up or you may never get it started again. Stan PS these guys are few and far between and are $$$$$$$$
Old 12-17-2010, 06:49 PM
Mariner
Simply turn down the boost a little.
-Tom
Old 12-17-2010, 07:43 PM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
Originally Posted by Easy Rider View Post
Fred,
Easy
if 50% power is without boost then removing it wont effect that 50% range, maybe even help as you have just a removed an inlet and exhaust restriction so maybe gain some efficiency
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 12-19-2010, 07:44 AM
"So it would seem a turbo engine would be actually less efficent than a NA engine at low speeds .....but what low speeds."
Below the RPM where there is a pound of boost or more.
This limits the bottom rpm of a turbo usually to above that of a NA.
While a NA may be happy at 1200 rpm (prime genset RPM) the turboed may need 1500rpm to get even a bit of boost.
FF
Old 12-19-2010, 01:26 PM
Mariner
It depends on the size of the turbo and, more specifically, the housing size.
One can easily design an efficient turbo system.
-Tom
How to design a diesel engine? arvi DIY Marinizing 14 12-15-2011 01:19 PM
diesel engine mounts muzboat Powerboats 4 03-28-2009 09:48 AM
Diesel Engine for sale wriand955 Marketplace 2 09-18-2005 11:07 AM
diesel engine ferryman mietchan Diesel Engines 1 06-15-2005 09:18 AM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 03:06 AM
