| titan alloy progect i need some advice for the instalation of the dry exaust sistem ., the motor (diesel kubota ) 27hp my other cuestion it's regarding the cooling opcions,to avoid salt water intake on the heater exchanger and fitings through the hull, could be posible to instal the keel cooler inside of the hull made a chanel welded of 3 or 4 ft cooling the fresh water heater , my idea is that could be posible on aluminim hull ,but i need advice from your gays open for ideas cheers carlos bairo |
| Aluminum pipe (marine grade) will work fine . Dave Geer gives a complete list of pipe size vs heat rejection in his book. The other process is an aluminum box welded into the hull with a laberinth to send the coolant back and forth in contact with the sea . Big advantages of this system is no winterizing , no drag and the stock coolant pump is far more reliable than rubber impeller pumps. |
| thanks fred for you reply ,i will do more research beacause the sistem has to be calculate acording to the engine zize. cheers carlos bairo |
| what kind of boat will nasa design for the methane sea on the moon Titan | Boston | Boat Design | 42 | 12-26-2009 06:38 AM |
| 8' Tiny Titan (hydro) turning stability | MR2-GTrevor | Stability | 3 | 07-24-2008 06:23 PM |
| Titan or Goliath | Tow boat | Boat Design | 4 | 06-06-2006 02:51 PM |
| starting deck progect need advice. | luisjg | Fiberglass and Composite Boat Building | 2 | 04-10-2006 05:42 PM |
