Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 07-22-2010, 12:31 PM
Shibumi Shibumi is offline
Rep: 10 Posts: 12
Thoughts on re-power for 70' M'Sailor?
Hi Guys,
First post on here so go gentle!
A bit of an unusual one;
I've been around boats since the 1960's but I recently bought a 21 meter Turkish 'Gulet' - as much for it's live-aboard volume as anything else.
It actually sails and motors better than I expected. I've done all the Ocean racing I want to, so now it's just gentle plodding (semi-retired) with the family.
But I want to move the boat at a fairly rapid (say 8-10 knots) 'make progress' basis between cruising grounds when required (e.g. UK to the Med or UK to Scandinavia etc.) 200 nautical miles per 24 hours would be acceptable.
The boat currently has the original 6 cyl Ford 2725 rated at 140hp. It runs very sweetly and reliably but it's getting on a bit (like me) and probably only kicks out a true 100hp + (ish) these days. 6 knots is about it.
Waterline length is about 50' (15m) and I estimate cruising displacement at around 40 tons (90,000lbs).
The engine compartment has bags of room - about 15' length and the full 18' beam - so I could fit in three engines if that was the decision.
My thoughts so far;
1. Retain the existing Ford albeit rebuilt and fit a further 1 or even two 4 cyl Fords (Say 80hp each) as wing engine / Genny / Hydraulic powerpacks.
i.e. Many common parts such as injectors etc.
Would also give many different power / motor-sailing options (yes she does sail reasonably well).
or,
2. Go for a new main engine in the 200-250 hp range (perhaps John Deere 6068 Turbo at 215hp or 6081 M1 @ 235hp) or equivalent Cummins etc.
I'm also not averse to considering CPP on the above (I've got a little 27' with a Sabb set up and I know the quality / advantages of their gear).
We normally sail short handed (Self, Wife and 11 year old daughter) even on 30 meter stuff so reliability / back up systems are essential.
I would consider a computerised main engine but only if I had a basic (clanky) back-up.
Any thoughts chaps?
Steve
Old 07-22-2010, 12:57 PM
apex1
The Deere 6081 would be my choice, and a Hundested CPP.
Are you in Turkey at present? Could probably assist you there. (I am in Fethyie)
Regards
Richard
Old 07-22-2010, 04:31 PM
Rep: 10 Posts: 12
Hi Richard,
The boat was built in Bodrum but is now in the UK - it goes into the (indoors) shed next month to start the refit.
Steve
Old 07-22-2010, 06:12 PM
raw raw is offline
Rep: 59 Posts: 133
Just a thought...Does this boat have a full keel in which the shaft is effectively contained.
If not, I would look at a self feathering prop such as Autoprop rather than the CPP. Smaller shaft and Brackets etc make for a much less "draggy" solution ime.
I did a larger triple screw yacht a few years back with the Autoprops/exposed shafts and client was impressed with them overall.
Old 07-22-2010, 06:25 PM
Rep: 10 Posts: 12
Yes Raw,
It's a full length keel with the usual deadwood Fwd of the Prop and rudder astern. The keel is probably about 40' long with 4' draught Fwd and about 6'6" draught aft. Think long keel, heavy disp. wooden fishing boat.
Steve
Old 07-26-2010, 10:54 PM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
If the boats in Europe you will be buying a new electronic engine unless you find a second hand one.
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 07-27-2010, 03:54 PM
Rep: 10 Posts: 12
There is a very ample supply of 'New' i.e. unused, still in a crate, but probably a few years old, marine engines over here. As soon as a new EU regulation comes in, old spec engines cannot be sold for new boats but can be used for re-powers on old boats.
Plenty of choice.
Steve
Old 07-31-2010, 07:01 PM
Carteret Carteret is online now
Rep: 122 Posts: 106
If you could find one, not familiar with the EU's market, a 3306 Caterpillar is just about as bullet proof as you can get.
Power Tri... thoughts? tallshipskip Multihulls 7 10-06-2009 07:10 PM
70' One off questions GoSlow Boatbuilding 10 04-11-2007 01:14 PM
Catamaran Plans Wanted 40-70' yhxaig Boat Design 0 08-08-2006 06:44 PM
July MotorBoat mag - 70' VSV? mark424x Boat Design 1 07-21-2006 08:15 PM
Cary 70' gonzo Powerboats 5 08-25-2003 10:11 PM
