Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 10-27-2006, 08:50 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
Taping into keel cooler?
Is it common to tap into the keel cooler to also cool engine and/or transmission oil coolers? If so what seperation of intake/return fittings are needed? Do you intake befor cool coolent enters the engine and return it downstream past the engine hot return?
Wiuld a seperate circulating pump interfear with the engine pump?
Thanks.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 10-31-2006, 05:33 AM
Rep: 700 Posts: 3,208
To keep with the simplicity and reliability the usual is to keel cool EACH item will get there OWN cooler.
However if you look at how a boat is cooled with sea water , with a heat exchanger for the tranny , it should be useable for you.
In other words the engine coolant will use a simple heat exchanger to cool the tranny , and the engine cooling from its keel cooler will just work a bit harder.
NOT OK if youre doing air cond or hold sized refrigeration , there a seperate keel cooler is needed.
The water leaving an engine is cool enough to additionally cool a transmission.
FAST FRED
Old 10-31-2006, 02:05 PM
ted655's Avatar
Rep: 122 Posts: 641
Thanks. I forgot but yoi are right. I meant using the engine coolent to circulate through "heat exchangers" for the auxillary units.
Closed water cooling conversion and tran cooler mlcorry Propulsion 2 06-08-2006 07:38 AM
Fin Keel to Lifting Keel on my Columbia 28 SteveWinNH Sailboats 5 04-05-2006 06:35 AM
Selecting transmission oil cooler size Gregscalade Powerboats 1 12-22-2005 06:05 AM
Keel Foils (optimizing a 70's keel) ErikG Sailboats 9 06-28-2004 10:58 PM
Replacing an iron keel with a lead keel. Kris-Stockholm Boatbuilding 4 06-21-2004 01:45 PM
