| small V4 or V6 turbo diesel Does anyone make a low profile 100-200hp diesel? V4, V6 horizontal oppossed 4, 6? Something small to replace a merc 3.0 (21 inch height) Seems like a yanmar 4jh is 125hp and 27 inches tall, but a vw v8 is 350hp and 29 inches tall. Why isn't there something shorter in the low horsepower? |
| Volvo's D3 is a tad under 21" from crank shaft center to top of motor. Yanmar's BY series 21.5" from the crankshaft center to the top of the motor. The Volvo is offered in 140, 170, 200 and 220 hp. The Yanmar in 150 and 180 hp. Karl2 |
| I'm looking more for over all height being in the 18-20 inch range. I've been looking and still finding nothing. Maybe if someone would marinize the new Subaru Boxer diesels, or maybe the Ecomotor OPOC might be out soon. |
| Sounds like you shouuld be looking for a flat, opposed engine not a "V" at all. Try VW or what about some of the motor cycle engines, they get up to 100Hp+! Oops, those certainly aren't diesels now are they... -Tom |
| Yeah I was looking at the Rotary Engines actually. |
Depending on how it is configured you would have either the exhaust or the intake side facing the bilge. Not sure what configuration I would prefer - Like choosing between plague and cholera. The width of the engine would be at the crankshaft center line. This could present a problem in a twin installation, deep V bottom. For a one-off, special application it may be a workable option but I don't think you will see a flat four (or six) mass produced for marine propulsion applications. Karl2 |
| That's okay, they hate you too! -Tom |
| The boxer diesel isnt lower than any other automotive diesel (they have mooved all the crap up on top of it) how much room do you have 18 or 20 inches, and how much room above crank level?? it would appear that the best way of doung it would be to either find an automotive diesel and perpaps shortening the oilpan or if you really really needed it to be 18 inches tall, buying an inline 4 or 6 and laying it on its side, but thar would require modifying the oiling to dry sump which costs a grand or two depending on parts and your skills a Jonn Deere engine would propably be well suited as you could add scavenging ports to all the sheetmetal covers on the left side of the block and plumb them to the scavenging pump a dry sump would also facilitate oilchanges or how about this one: for that price a couple of grand at the local racing engine builder flipping stuff 90 degrees and building a dry sump oiling system seems within reason http://cgi.ebay.com/ebaymotors/Cummi...Q5fAccessories |
| small inboard diesel or outboard | rberrey | Multihulls | 9 | 03-05-2011 09:26 AM |
| ''small'' diesel for 20' scow | bean surchwell | Diesel Engines | 2 | 12-01-2010 06:37 AM |
| Subaru Boxer Turbo Diesel Engine Set for Geneva Premiere | kach22i | Diesel Engines | 6 | 02-27-2007 08:03 AM |
| Marinizin small turbo diesel | mholguin | DIY Marinizing | 10 | 09-21-2006 05:30 AM |
| Small diesel DI and Turbocharged. | fcfc | Diesel Engines | 8 | 07-25-2006 03:08 AM |
