| Here we go Displacement hull 66 tons Gross loaded tons 65 Net tons 33 Hull Speed 9.4 2 Volvo 225 HP diesel engines Model TMD100Ak 1 Gear Box SCG MF16-11c 1 Saffle adjustable Pitch Prop Running both engines in calm seas with SOG of 8 knots uses 60 litres/hour How many litres/hour with 1 engine ?? at say 7 kts in calm seas ?????? |
| I have done a few tests on displacement megayachts 40 to 50 metre and they all used way less fuel on one engine at less than full speed I guess it depends on the power to move the hull versus the gph with the 3412 or 3508's running with very little load before they start to get much boost. The problem is you can overload a single engine if you nail it and usually the gearbox is not designed to windmill unless supplied with prop side oil pump. Was handy to know at what rpm you went to overload just in case you did need to run hard on one engine Was also interesting to know that it was always at a different rpm ( by a few hundred) on each engine due to one gearbox going the other way.
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| To Clarify: The vessel has only ONE Gearbox, One Propeller " The Vessel 62.5 ft LOA 49ft LWL Displacement hull 66 tons Gross loaded tons 65 Net tons 33 Hull Speed 9.4 2 Volvo 225 HP diesel engines Model TMD100Ak 1 Gear Box SCG MF16-11c 1 Saffle adjustable Pitch Prop Running both engines in calm seas with SOG of 8 knots uses 60 litres/hour The Question :- How many litres/hour with 1 engine ?? at say 7 kts in calm seas ???? " |
| How many litres/hour with 1 engine ?? at say 7 kts in calm seas ???? If your displacement is correct at 66long tons , and the number is not the registered tonnage , which is volume not displacement . 2HP per ton , perhaps 2.5 should do the job, so the question becomes how efficiently does the single engine create 150-160HP ? The simplest solution , that IS worth the bucks is to install a Flow Scan that hooks to both engines and the GPS. This will give instant reading of MPG. www.floscan.com/ FF |
| f you have the fuel flow you just need to spec sheets of the engine to work out how much load they are under at that speed. If the BSFC goes down at a higher rev then you would be better off with one engine thats an easy one. To work out anything else you would need the load curve ( some call that the prop curve) of the vessel
| Cat Centerboards Single vs Twin. | Zed | Multihulls | 31 | 02-13-2010 03:02 PM |
| twin rotax vs single merc v6 | LEASEGUY | Jet Drives | 1 | 11-02-2008 04:49 PM |
| The way to lower emisions and save fuel/money | StianM | Diesel Engines | 0 | 05-25-2007 02:35 AM |
| twin single keel | Garth | Boat Design | 5 | 08-18-2006 05:21 PM |
| Single Inboard To Twin Outboards | RYANPO | Boat Design | 7 | 07-20-2006 05:07 PM |
