Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 08-15-2006, 01:59 PM
firepiper firepiper is offline
Rep: 10 Posts: 33
repower question...
Hello, I found a really nice deal on a running pair of takeout Volvo TAMD41's (200 hp). I'm wondering if they would be enough to repower a 35 luhrs (downeastern design) Alura. 12600 lbs. It originally had twin small block chevy's. The horsepower is less, but, will the torque be better? I don't mind going a little slower, I realyywant more effieciency. Any thoughts? Mark
Fire Escape -1987 Luhrs Alura 35. Twin Crusader 454 model 350, MPI, 1.91:1 VD
1969 Thunderbird Formula 23', sadly sold.
Old 08-15-2006, 03:36 PM
bilgeboy bilgeboy is offline
Rep: 45 Posts: 157
That should be plenty of power. The torque is definately way better with diesels. I've got twin 135's in a 32' bayliner (Newer models are called 35' with integral bow pulpit and swimplatform). I love the efficiency. I can cruise for days at hull speeds, now getting an easy 16 knots at WOT on calm seas.
You will need to reprop, and I'm sure someone here can help with those calculations. I wouldn't sweat the speed calculations, just figure out what transmission ratios and prop diameter and pitch will make sense with those engines on that hull. If you can get a good deal on the engines, grab 'em. Diesels rock.
I would love to follow the installations (might even be able to offer some helpful advice) if you will continue to post the project here.
Go for it, and good luck!
Mike
Old 09-02-2006, 10:22 AM
alex fletcher alex fletcher is offline
Rep: 18 Posts: 54
lovely thay will do a great job we have fitted a number to a number of vessels you will not lose speed at all u should gain speed a little and the boat will come out of the hole faster. you will need the services of a Prop scan franchise to get the best results of course, as your porps have to be just right you need the science
Old 10-14-2006, 12:30 PM
rpeter46 rpeter46 is offline
Rep: 10 Posts: 2
1969 Formula
Can you send me a couple pics of your 1969 Formula? I recently bought a "1973" Formula Thunderbird and I'm getting the feeling that the information on the title is wrong. Can you also tell me where to find the HIN on that boat? Thanks, I really appreciate it!
Old 10-15-2006, 09:13 PM
Rep: 10 Posts: 33
I'm not positive, but, I don' believe there were hin's back then. Mine did not have one.
Old 10-15-2006, 10:24 PM
Rep: 10 Posts: 2
1969 Formula
Thanks for the HIN info. Can you help me out with some pics?
Old 10-18-2006, 12:58 AM
StianM's Avatar
StianM StianM is offline
Rep: 114 Posts: 577
Torque don't mather.
it's the power at diferent revs.
The Diesel has the power spread over a larger area off the RPM curve so you should experience faster aceleration at low revs and speed's.
You should get out off the water a lot quicker.
Old 03-06-2007, 12:39 PM
fish1860 fish1860 is offline
Rep: 10 Posts: 3
Firepiper. I am currently looking at purchasing a 1988 Alura 35. with 454's
I addition to a marine survey can you give me some insite on what to look for or what to out for before I get this. Any help would be greatly appreciated.
Old 03-09-2007, 07:22 AM
Karl2 Karl2 is offline
Rep: 34 Posts: 67
TAMD41 in 35' Luhrs
Should work very well - You should loose some speed but be able to cruise the same and for less fuel.
A couple of things to consider with the 41's: Make sure you run a 2:1 gear ratio (If they come with Volvo gears it will be 1,9x:1 and that is fine) and go for 18-19" diameter wheels. Avoid 1.5:1 gear ratios - Will not work well with these motors in this boat.
Karl
Cruisers Inc Repower mikemac Propulsion 5 01-31-2012 06:37 PM
Catamaran repower Devooo DIY Marinizing 3 07-30-2006 05:08 PM
Need help with repower issues bntii Boat Design 4 06-15-2006 08:16 AM
diesel repower bertram28 Diesel Engines 1 11-17-2005 04:58 PM
diesel repower question notlostmaybe Propulsion 1 05-15-2005 02:13 AM
