| repower with Cummins 6B NA or 4BT Turbo 4 Guys I am looking at repowering a 42 trawler that has 120 Lehmans. I would prefer to use Cummins but I can choose 6B or the 4BT, either would have ok power. What will the cruise fuel economy look like with; a) either 6 or turbo 4? b) on one engine with the other windmilling. c) what does the engines power curve versus the prop curve look like when comparing the 2 for a displacement boat? Thanks in advance Powerabout |
| Some Cummins fuel consumption data here (page 7): http://www.cmdmarine.com/PDFs/4081938_1104.pdf At 130 vs 120 HP, the 4BT seems to have an slight edge in fuel consumption. In the boat, that edge should increase, as it also has a 200kg weight advantage. For the rest, find the Cummins Marine distributor for your area; they should have access to that data.
__________________ Best, Charlie |
| u used to work for cimmins years ago, I also used the 4b a lot is sailing yachts I would use the John Deere teir 11, 4.5 Why cos it a wet linered engine, seize a piston and its easy fix one piston one liner same as big engines The 6b engines are fine engines dont get me wrong, but the Deere has(here) a very significant price anvantage The Deere is happy to run at 1400 , or 1200 all day, or 2600, there are three ratings 1,2,3, 120 --135 bhp depending upon hours per year |
| Cummins vs Yanmar | vjb | Diesel Engines | 67 | 03-27-2007 06:56 AM |
| Turbo freak out | Richard Hillsid | Powerboats | 3 | 03-28-2006 01:36 AM |
| Cummins 3.3 | george allard | DIY Marinizing | 2 | 03-04-2006 04:02 AM |
| Cummins turbo diesels | Powerboats | 4 | 08-03-2005 04:23 PM | |
| Cummins 555 | ABoatGuy | Propulsion | 3 | 07-31-2005 10:47 AM |
