Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 08-09-2011, 03:30 AM
Brian@BNE Brian@BNE is offline
Rep: 140 Posts: 222
Seems good advice to me re: engines. I'd look at a Zeus drive instead of a traditional sterndrive leg. Depending on space, which could be generous on a houseboat, you may be able to engineer one that can be raised out of the water when not in use.
Old 08-19-2011, 08:11 PM
kapnD kapnD is offline
Rep: 19 Posts: 143
Originally Posted by Wado View Post
Is the Cummins 6BT compatible with Mercruiser sterndrives?
I'm afraid the short answer is NO, the reason, as mentioned above is inability of gears to handle the torque.
The Cummins 6b is a great motor, but makes its power at way lower revs than a comparable yanmar or volvo, and is a notorious destroyer of stern drives.
Volvo is making new sterndrives that are said to be capable of diesel torque, however I wouldnt jump on the bandwagon just yet, but let the dust settle until it becomes a proven product.
Depending on how much use the boat will actually get, gassers may be much cheaper in the long run anyway, you just have to pencil out the alternatives.
Newbie with a few (repower) sterndrive questions mbjeeper DIY Marinizing 5 08-01-2006 09:36 AM
diesel repower bertram28 Diesel Engines 1 11-17-2005 03:58 PM
best sterndrive for diesel brianhayes1 Sterndrives 0 11-12-2005 09:27 AM
diesel repower bertram28 Propulsion 3 06-16-2005 05:39 PM
diesel repower question notlostmaybe Propulsion 1 05-15-2005 01:13 AM
