Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 02-03-2009, 11:39 AM
twakeley twakeley is offline
NAME Student
Rep: 16 Posts: 30
Propeller weight distribution
All,
I'm trying to resolve some forces due to the loss of a propeller blade. I have the total weight but am unsure of the weight of each blade. Is there a general rule of thumb for weight distribution between the blades and hub of a propeller? Does the proportion change due to the size of the prop? I'm thinking 40% hub and 60% blades as a starting point.. ideas?
Trevor
Fast. Cheap. Reliable. Pick two.
Old 02-03-2009, 05:47 PM
Olav's Avatar
Olav Olav is offline
cand. arch. nav.
Rep: 337 Posts: 198
I don't know of any rule of thumb but it should be fairly easy to determine the weight of the hub by measuring/calculating its volume and multiplying it with the material density. The difference between the total weight and that of the hub then logically is the weight of the blades.
The proportion between hub and blade weight is constant unless there is a non-linearity between prop diameter and hub size, i.e. a bigger propeller may get away with a proportionally smaller hub than one with lower dia.
All the best, Olav GER-1045 ____/)_/)/)___
Old 02-03-2009, 06:31 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2356 Posts: 2,478
Think of Archimedes and you'll figure out how to calculate a single blade weight.
Weight balance. Will it ride better with weight in the rear or dead center? clctrader Boat Design 4 01-24-2008 01:12 AM
Weight Distribution in the Ends nc sailorman Sailboats 1 06-19-2007 02:53 PM
weight distribution gregs Boat Design 9 06-17-2007 11:08 AM
Weight distribution for an electric launch Sander Rave Boat Design 12 11-08-2005 06:21 AM
Average Human Weight, Safe Excess Weight, &c. Free Pirate Boat Design 12 03-14-2005 02:40 AM
