Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 03-28-2008, 11:04 AM
eng.ibrahim eng.ibrahim is offline
problem with cumminsMercruiser 4.2 ES
hi ,
the problem is due to two diesel engines sinked .
CumminsMercuriser 4.2 ES 250hp,ECM.
i wash the two engines with diesel and cranked the engines.
so i must start up the engines with out the control panel!!!!!
but the problem the engines dont fire, knowing that the fuel pump has shut off device and i gave it a signal but the problem exsisting.
any one has experience with this engine can give help.
Old 03-28-2008, 04:16 PM
Previous Member
Rep: 0 Posts: 0
I think these are electronic controlled engines?
If so you wont start them without the panels
You could try hotwiring the fule shut down solenoid,
Old 05-25-2008, 05:58 PM
dmcc dmcc is offline
Rep: 10 Posts: 10
hi there, those engines i believe have whats called an ECU unit "a brain" you would need the control panal but if the ECU has had to much water damage it would need replacing and can be costly£££
Problem! babakshabani Surface Drives 14 11-13-2007 07:26 AM
TV problem yipster OnBoard Electronics & Controls 12 11-07-2007 10:32 AM
A Problem in Maxsurf bhabanism Software 2 09-01-2006 12:22 PM
Do I have a problem?? hiracer Metal Boat Building 16 08-29-2006 08:05 PM
problem electricvoodoo Boatbuilding 7 09-09-2005 06:00 AM
