Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 06-15-2009, 07:59 AM
flyinwall flyinwall is offline
Rep: 10 Posts: 22
please verify this motor is a perkins 4108
as the title suggests i need to verify that this motor i have is a perkins 4108 if it is not then what is it and can anyone help with identifying clae gearboxes
cheers in advance
Old 06-17-2009, 02:28 AM
hartley hartley is offline
Rep: 27 Posts: 90
g'day flyinwall yeah looks like a 4-108 ,the numbers stamped into block ,which are in the correct position ,however i can see numbers 07 the rest are covered in paint ,you would need to clean that up for positive identification ,must likely it is a 4-107 .a easy way to see what it is the 4-107 has 7/16 head bolts or studs ,the 4-108 has 1/2 inch .there are 3 engines that are very similar they are 4-99 4-107 4-108 .re the clae they were very popular in the 50s 60s and 70s they had a cone clutch and made a very satisfying noise when put under load there was another similar gear around that time ,but can't think of the name of it ,i have an idea it was made by a firm called Hardman I had one behind a simplex engine, sold it to Jack Pompei of Mordialloc for 200$ over thirty years ago ,alas everything gone now,too bloody old
Old 06-17-2009, 04:08 AM
Rep: 10 Posts: 22
do you know what the rated power output is for these engines as i was told it was 35 hp but i have heard it could be as much as 50hp
Old 06-17-2009, 03:52 PM
Çemberci's Avatar
Çemberci Çemberci is offline
Rep: 133 Posts: 117
perkins
Look at the our site for indentifing its horsepower and rpm.
http://www.engine-cemberci.com/engin...NS/PERKINS.HTM
oktay çemberci
Perkins 4108 rear seal replacement Chuck Losness Diesel Engines 13 01-03-2010 09:11 AM
Perkins 4108 thecopperdoc Open Discussion: All Things Boats & Boating 0 03-01-2007 11:31 AM
Perkins 4108 Thermostat Replacement delphi Diesel Engines 0 12-24-2006 03:30 PM
perkins 4108 ratboy Inboards 1 12-16-2006 08:40 PM
Need fuel lines for a Perkins 4108 MarioCoccon Sailboats 3 10-05-2005 03:35 PM
