Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 09-25-2010, 08:27 PM
Roly Roly is offline
Rep: 222 Posts: 490
Phosphoric acid to clean heat exchanger.
Does anyone know the dilution ratio for phosphoric acid to clean the raw water side of a heat exchanger or do I use it neat?
I have pulled the heat exchanger/exhaust manifold on a Yanmar 3GM30F and are going to bath it in H"x"PO4.
Is there a good product for decarbing the exhaust manifold insides? Or is it better to do it with an abrasive at a
a reconditioning shop?
Any advice from the experienced, much appreciated.
Old 09-25-2010, 09:56 PM
mcollins07 mcollins07 is offline
Rep: 156 Posts: 206
Roly,
I used a product called CLR to clean my heat exchangers. I rinsed very well after running the engine up to operating temperature with it circulating.
phosphoric acid comes in different concentrations. No one can really comment on how much to dilute it without knowing the starting concentration. Phosphoric acid, in a concentrated form, could be dangerous to a heat exchanger. A safer approach would be something like oxalic acid. You still want it diluted but it is not as strong an acid, thus concentration is a little less critical.
I have not tried to clean exhaust manifolds.
~ Michael
Old 09-26-2010, 12:19 AM
Rep: 501 Posts: 1,767
Ditto on Oxalic acid. I buy a product called Rust aid used to take rust out of sprinklers, it is mild enough to leave in there for an hour. Oxalic rinses off very well with plain water
Old 09-26-2010, 02:14 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
Phosphoric acid in commercial rust removers have concentrations below 12% for hardware store products or 5% for household products.
To use this in a heat exchanger doesn't make sense to me, unless the exchanger is made from steel and you want to remove rust. I would use 20% hydrochloric acid to remove lime deposits and flush with lots of water as soon as the acid stops foaming.
Carbon deposits can be easily removed with a high pressure cleaner and a wet blasting accessory.
Old 09-26-2010, 02:58 AM
Rep: 222 Posts: 490
Thanks everyone for your comments.
I have heard about the use of Lye but didn't want to go that extreme.
The Phosphoric application I got from Woodenboat forum (Detroit diesel) & they
prefer it over the lye but didn't give the final dilution. It is the weekend
and I am committed to do this today. Tomorrow it goes to the machine shop to get the
mixing flange milled flat.
Anyway it did the job well fizzing all the lime off in no time.
I've got it soaking in fresh water now with mild bicarb to make sure all the acid has gone.
http://forum.woodenboat.com/showthre...anger-cleaning
Unfortunately I also lent out my tub of Oxalic acid & can't remember who I lent it to!
Time for a lend book.
Old 09-26-2010, 04:08 PM
Rep: 222 Posts: 490
Update.
On removing the lime with phosphoric I managed to remove the heat exchanger tube assembly from the cast iron manifold.
The bronze/Cu/brass (?) tube assembly is installed in an Al tube!
Through the port it looked like stainless.
Hydrochloric sure as hell would not have been good on that.
The Al tube is not removable.
I guess if you pump the HCl solution thru, in situ,(without pulling the H.E.) it may not be a problem as the "O" rings should keep the solution on the raw water side.
Old 09-26-2010, 05:06 PM
Jelle Jelle is offline
Rep: 21 Posts: 3
Phosphoric acid is one of the main ingredients in cola (I kid you not), so I would just pour in a bottle or two. That is something the stuff is good for, otherwise someone might drink it accidentally.
Old 09-27-2010, 05:20 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Wrong, cola contains only trace amounts (<0.1%) of H2[HPO3], much weaker than phosphoric acid (H2PO4). Good to prepare a tender steak if you marinate it a couple of hours, useless to remove rust.
Old 09-27-2010, 06:20 AM
kenJ kenJ is offline
Rep: 56 Posts: 333
It's a good idea to read the labels before you use any of these products. Because of the heat transfer and ease of manufacture, most heat exchangers have copper tubes inside some sort of metal case. CLR states on the label not to use on copper. A couple products that are safe are Lime Away and RydLye. I know several folks that will pour a bottle of Lime Away into the HX at least once a year, let it set for several hours then reattach the raw water cooling lines and flush out.
Old 09-27-2010, 11:37 AM
Rep: 21 Posts: 3
http://en.wikipedia.org/wiki/Coca-Cola#Ingredients
http://www.wikihow.com/Make-OpenCola
Perhaps you should find some sources to back up your claim if you really need to say someone is wrong on the internet?
Old 09-28-2010, 12:54 PM
Rep: 1493 Posts: 7,447
Wiki is not a reliable source.
exhaust gas heat exchanger singleprop Diesel Engines 11 06-29-2010 09:17 AM
Heat Exchanger Surface Area Jellyfish84 Inboards 0 02-04-2009 08:57 PM
heat exchanger cleaning kenJ Diesel Engines 2 12-15-2006 10:04 AM
Building a heat exchanger into the hull djackson99 Powerboats 42 03-21-2005 02:15 PM
Building stainless heat exchanger guest Powerboats 4 08-11-2004 03:46 PM
