Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 02-12-2008, 04:37 PM
the ucf the ucf is offline
Perkins 4236 injection pump
Hi
Is any one able to advise as to whether a pump on my 4236 has to be changed for one with the exact same codes. Unfortunatly there is no cav plate with the codes but some one has engraved them on to the casing but im not able to deciepher them correctly this is what i believe the say.
3248440
29472pj
1.850.2660
the code ending in pj dates the engine to march 67 which i think would be about right. As for the first one the only cav pump i can find with a similar code is 3248f440. i found that here http://www.omapdiesel.it/catalog/101_132.htm Any help will be greatly apreciated as i havent been able to use the boat for ages now and need to get it fixed.
Cheers in advance
Fuel injection pump, a unexpected problem. CDK Diesel Engines 9 07-07-2011 02:03 AM
Perkins 4108 block circ pump??? Grommit Diesel Engines 4 04-09-2007 07:54 PM
(sold) SULZER 40/48 injection pump assembly BRAND NEW Micom Diesel Marketplace 0 08-07-2006 06:28 AM
Heat Pump => Vacuum Pump Inquisitor Boatbuilding 7 11-12-2005 09:29 PM
Fuel Injection? LKJR Propulsion 0 07-14-2004 05:31 PM
