The advance mechanism compensates for this by advancing the timing. Engines with pumps not fitted with an advance mechanism will generally have the timing advanced at idle, and the timing optimised for a particular speed/load. This way the timing 'naturally' retards until it's at the optimum point for the speed, whether thats 1500/1800/3600 rpm for a generator, or for cruising speed or a set speed for a CP prop, or whatever. If the pump is fitted with an advance mechanism, then failure would cause smoking, excessive fuel consumption and loss of power. Running the engine at idle (low loads) for periods of time can cause the problem of fuel in the exhaust (wet stacking), partly because the engine cools down. I see this all the time in engines such as Kelvins.
__________________ There is nothing that roses or duct tape can't fix. |
Believe it or not, I know quite well how engines work and so do you. When responding to a question we have to rely on the data supplied, unless that is obviously wrong. If a rebuilt engine with only 400 hours keeps expelling unburnt fuel at idle only, the injection and hence the combustion starts too late. At higher rpm an advance mechanism will improve that. With an engine idling at only 450 rpm, the timing -when set correctly- will always be fairly late. There are many other possible causes like a burnt or damaged exhaust valve, broken rings or an injector that doesn't close, but then the question should have started with a different engine story, like just rebuilt or a very worn, neglected one. |
| For Cdk Hi CDK Will it be enough power if I install diesel engine (VW golf 1986 NON turbo 1.6) On bayliner with cuddy 17ft long(1989) ???????? THANK YOU ALEX |
| CDK is right it needs the pump moving a few degrees in the opposite direction to the pump drive rotation. this will allow the fuel to be burnt fully before the exhaust valve opens ...I think what Alba diesels is saying is probably right ...if its not advancing then it is retarded relative the the correct igniton positon....Ist all a queston of where you start and what logic framework you are using ... |
| kevan a 17 ft needs about 100 hp if you are going to get up on the plane and do about 40 kts .....so your 1.6 produces what 60 hp ??? so know you know where you are .....for a canal ok for the open water underpowered .. |
A VW1.9 from a Passat (AAZ) or from a van (ABL) does it much better. Size and weight are about the same.
| Perkins 4-108 0verheating | jimisbell | Diesel Engines | 46 | 03-14-2009 07:58 AM |
| Perkins 4-108 on a Volvo/Penta 280dp???? | sailinphelan | Sterndrives | 1 | 12-15-2008 12:40 AM |
| Perkins 4-108 | bob24 | Diesel Engines | 9 | 01-11-2008 06:17 AM |
| Need fuel lines for a Perkins 4108 | MarioCoccon | Sailboats | 3 | 10-05-2005 02:35 PM |
| not exactly a Perkins 4/108 | Guest | Sailboats | 0 | 12-11-2003 12:12 PM |
