| oil cooling a PRM gearbox We want to design a keel cooling system on a PRM gear box, would appreciate any ideas |
| Far easier to tie the gear box into the engines cooling system. Is the entire package to be leel cooled. For a fine built setup check out Walter Keel cooling Co that has been doing keel cooling for 5 decades. FF |
| In the older huckins to cool the veedrive, they put whats equivelant to a generater sized heat exchanger. the oil from the veedrive goes through one side and a small portion of the raw water being pumped through the motor is diverted to said heat exchanger and out charged though the side of the boat |
| My Tecnomarine gearboxes (now part of TwinDisc) are cooled by a copper tube that goes through them, ending with a hose stub on both ends. The raw water pump feeds cold water to it, the output connects to the engine's heat exchanger manifold. |
| electric oil pump for oil changes and priming | simon | Diesel Engines | 13 | 11-14-2008 06:54 AM |
| converting from fresh water cooling to keel cooling | Big H Buck | Diesel Engines | 9 | 07-06-2008 07:02 PM |
| Reduction gearbox | martinwill | Inboards | 9 | 09-25-2007 04:46 AM |
| Gearbox | cookiesa | DIY Marinizing | 14 | 05-02-2007 04:42 PM |
| Gearbox | Poida | Powerboats | 0 | 08-20-2006 08:12 AM |
