Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 12-28-2010, 06:08 AM
ecflyer ecflyer is offline
Rep: 72 Posts: 76
need help finding fuel fittings
I need help finding a good place to buy fittings to fit a Racor 500 filter. I think the in & outlets of the fuel filter are 3/4" national fine but the install pamphlet does not mention anything. I need to get from the Racor filter to 3/8" hose barb. All the fittings I am finding are national pipe thread and don't fit. Any help would be greatly appreciated.
Have a Great Day
Earl
Old 12-28-2010, 06:35 AM
kenJ kenJ is offline
Rep: 56 Posts: 333
According to their web site, the fittings are either 3/4-16 UNF or optional 3/8 NPT. If you have the 3/4 it is designed to have an o ring to make the seal. If you can't find the fittings in the hardware store, might want to try a shop that repairs/services 18 wheelers.
Old 12-28-2010, 07:17 AM
Rep: 756 Posts: 3,328
Get thee to the local Hydraulic store.
The place where they make up hyd hoses as you wait.
Here in FL its "Parker- Hanifin" (SP?) that will have just what you need to install the Raycor.
Look for bulldozers on trailers and garbage trucks parked outside.
FF
Old 12-28-2010, 10:27 AM
mark775
"Look for bulldozers on trailers and garbage trucks parked outside." - Used to be logging trucks, too. It's the same no matter where you live, I think!
Old 12-28-2010, 10:37 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Sometimes irrigation shops can help out too.
-Tom
Old 12-28-2010, 12:53 PM
murdomack murdomack is offline
New Member
Rep: 267 Posts: 282
We had a thread running a couple of years ago and the filters turned out to be Racor 500FG's. I have these on my own boat and the threads are 9/16" UNF, but I'm sure the new ones are 3/4" UNF.
I had the website for the Racor fittings supplier, but when I tried it just now, they are rebuilding the site or something.
Here is some of their older fittings, but I don't see any reference to particular filters, there are various Racor 500 models and yours should have letters after the 500.
http://www.ftginc.com/2000/distribut...20Fittings.pdf
You could phone them,
Last edited by murdomack : 12-28-2010 at 01:15 PM. Reason: The website is the old version they link you to
Old 12-28-2010, 05:53 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Try http://www.amazonhose.com/
Hoyt
Old 01-11-2011, 07:04 AM
WickedGood
NAPA Auto Parts.
Try the biggest NAPA in your area. Not all have the Hydraulic Hose Machine but the ones that do will have the fittings you need. I have them make up 6,000psi hises with swivel fittings when I need them
as far as 3/8 NPT Home Depot has those and you can get stainless steel braided 2,000 psihigh pressure hose in the plumbing/appliance dept to work for fuel & hydraulics cheap. OK for a little runnabout type boat with outboards
Old 02-21-2011, 04:33 PM
JimBoatsUK4 JimBoatsUK4 is offline
Rep: 10 Posts: 3
Parker are Racor disrtibuters so should have these off the shelf. Im pretty sure its a 3/4" UNF with an O ring
Through hull fittings 42 below Metal Boat Building 65 03-23-2011 11:47 PM
Fuel fill fittings M&M Ovenden Boat Design 10 06-09-2010 06:44 PM
Deck fittings Mike Field Marketplace 0 05-07-2009 07:25 PM
sealing up fuel tank fittings ducaes Boatbuilding 4 06-01-2005 02:37 PM
FRP Fuel Tank Fittings? Fixin2 Fiberglass and Composite Boat Building 1 03-04-2005 01:45 PM
