Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 02-17-2009, 06:33 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
Mid speed diesel engines
Hi folks,
I am making a 35m steel hulled displacement pleasure boat.
I have searched a lot for mid speed diesels in the <1000 hp range really to no avail.
The Lugger L6170 is no longer available (it was a 24 litre Komatsu), the MAK M20 is available but it is really too big, and I have NO information on anything in between that is a viable economic proposition.
I need 620kW...anything a bit more, up to 1000hp is OK for the owner as we can then get max speed up a bit if necessary, but I cannot find any engines that cibe me 1000hp or slightly less without getting into high speed diesels such as Cat or Cummins.
Any ideas would be gratefully accepted.
Old 02-17-2009, 07:13 PM
Olav's Avatar
Olav Olav is offline
cand. arch. nav.
Rep: 337 Posts: 198
A quick search on "current models" at boatdiesel.com produced the Niigata 6M26BET with 625kW @ 400 1/min and "continuous duty" rating. All other results were engines which run at (much) higher rpm.
Hope this helps a bit...
All the best, Olav GER-1045 ____/)_/)/)___
Old 02-18-2009, 02:01 AM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
did you try Deutz, they are very easy to talk to
try the Wien branch ask for johannes, tell him Stuart sent you
becker.j@deutz.co.at
you know those long range longliners and tuna boats that venture Japan down to NZ and clean across the Pacific, they all have those slow engines
http://www.firststringservice.com/di...ine-yanmar.htm
http://www.firststringservice.com/diesel-engine.htm
wake up Lubs you bin on abt thsi for a whole year)
Old 02-18-2009, 02:17 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
I'm sure they are producing them in India. Something like Gujarat only bigger.. http://www.fieldmarshalengine.com/p_wcde.htm#1 Note that these are highspeed
Old 02-18-2009, 02:33 AM
Landlubber's Avatar
Yeah woosh, so right, I have done the build and general specs though, so I am getting there mate. Ta.
Old 02-18-2009, 02:44 AM
Landlubber's Avatar
I should have said also that I do not wish to spend over $500,000 for an engine, that is what they are asking for German engines....unreal prices.
Old 02-18-2009, 02:49 AM
Previous Member
Rep: 0 Posts: 0
this is my dream, for sale at 700k, with proper engines, converted North Atlantic trawler 119 feet, flamin' bargain
Old 02-18-2009, 03:00 AM
Landlubber's Avatar
Nice, some of those old girls really are good buys.
I bought a 160 footer in the Pacific once for *0k. She was "retired" because it cost too much locally to put her back into survey. I managed to do it for under 200K and she was a great Island Trader again.
MAK 500 hp@ 575 rpm.
Old 03-19-2009, 02:57 AM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 561 Posts: 1,052
Baudoin, Caterpiller, Kelvin, M.a.n, Scania, Duetz
Old 03-19-2009, 10:04 AM
apex1
The 1st is to forget (I do´nt say crap), the second may fit, Kelvin is by far to heavy, MAN is high tech, high rev., Scania is too small and like the first, and DEUTZ has one engine in that range, the TBD 616 (not made in India Teddy) call William Knudsen:
http://www.williamknudsen.no/EN/Defa...0&subtabid=560
Mitsubishi maybe worth a look too.
Regards
Richard
Old 03-19-2009, 02:43 PM
Originally Posted by apex1 View Post
The 1st is to forget (I doŽnt say crap), the second may fit, Kelvin is by far to heavy, MAN is high tech, high rev., Scania is too small and like the first, and DEUTZ has one engine in that range, the TBD 616 (not made in India Teddy) call William Knudsen:
Regards
Richard
i have heard baudoin are bad but can several hundred french & italian fishermen be wrong ,the're very popular,how can kelvin be too heavy, whats the boats tonnage,
Old 03-19-2009, 03:25 PM
apex1
Peter
I assume the fishermen are looking at the price mainly, otherwise I cannot understand their decision.
The Kelvin engines of similar output as a Mitsubishi is about 1000kg heavier.
The boat is a slender 90´ of about 80tonnes.
Regards
Richard
Old 03-20-2009, 09:12 PM
Landlubber's Avatar
The problem still exists, I am looking for a mid speed diesel, from 900 to 1200rpm, of 620Kw power, prefer inline......so far, for the boat of 220 tons, I have found no engine available.
The beautiful Komatsu (Lugger) is no longer available......
Old 03-20-2009, 10:24 PM
have you considered rebuilding an old Brons or Sulzer
Old 03-20-2009, 11:05 PM
Landlubber's Avatar
peter,
I am all for a rebuild, unfortunately the owner wants "new"....he will not accept a rebuild, even though we all know, the rebuild IS a new engine if it is done right, unfortunately I cannot convince him....such if life....thanks anyhow mate.
mid-sixties fiberglass speed boat feh Boat Design 3 04-15-2008 02:39 PM
list of diesel engines; pavel915 Diesel Engines 7 07-21-2007 04:34 PM
Truck diesel engines rajeshr DIY Marinizing 12 12-12-2005 09:48 PM
Isuzu Diesel Engines brian eiland DIY Marinizing 6 08-05-2005 03:02 PM
Diesel engines for sailboats ErikG Sailboats 3 02-17-2003 01:44 PM
