Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 11-03-2010, 01:56 PM
AtlanticPeter AtlanticPeter is offline
Rep: 10 Posts: 6
Marinizing Small Diesels
Recently posted about repowering a sailboat from gas to diesel.
Have been doing my homework and the Yanmar 1GM10 is looking about right.
Some respondents suggested marinizing terrestrial engines. Would be interested in opinions on the feasibility of marinizing small industrial/utility diesel engines for marine use. For the average backyard mechanic is marinizing: a) a great lower cost option - many of us do not fully appreciate; or b) a potential headache of hard to match components and escalating $ and time costs. This article would suggest the latter http://www.seaskills.com/DieselMarinization.html.
For example this Yanmar 2TNV70 seems like a deal- http://www.surpluscenter.com/item.as...atname=engines. However might there be aspects of this tractor/generator engine which make it inherently unsuitable as a starting point for marinization? What might these be? What about transmissions - are most non-marine Yanmar's matchable to some Kanzaki unit - are there other transmission options?
Any suggestions re: specific marininzing projects (e.g. posts, articles) would also be appreciated.
Thanks in advance for your opinions.
Peter
Old 11-03-2010, 02:38 PM
Rep: 1493 Posts: 7,447
It is a high cost option that a capable backyard mechanic can acomplish. There will be a fair amount of welding, fabricating and machining. It can be a great hobby and will keep you busy on those snowy winter weekends. The Kansaki is the same as a Hurth. They are built under license and parts will interchange.
Old 11-04-2010, 03:50 PM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
Atlantic,
The short answer is that unless you know how to perform the work, AND consider your time worth 0, it is going to be cheaper to buy a marinized engine than do it yourself.
Just think of all the parts you will either have to buy or fabricate at full price to marinize the engine, then think of all the scrap parts with little to no value you will have in your shop when you are done.
Old 11-05-2010, 05:30 AM
Rep: 756 Posts: 3,328
One cheat might be to get a crapped out boat engine , and rebuild it.
A good rebuild will usually last longer than the factory new engine if machined during the re build.
A second option might be to locate an "industrial " running engine that duplicates the marine engine and swop all the parts.
The kicker in the origional article is at the end,
"The best marine engines utilize heavy-duty industrial base engines, typically used in agriculture and construction
industries. These engines all have replaceable wet liners and very robust construction that allows very long life (typically
40,000+ hours) and economical rebuilds - this is vitally important to commercial customers who will accumulate over
8000 hours per year of running time if their application runs 24/7. <That type of construction is completely unimportant
and needlessly expensive in a pleasure boat application that is lucky to run over 200 hours a year."
He is talking HUNDREDS of HP,
For most of the smaller boats with under 2 GPH of fuel burn at cruise 30-40hp ANY small industrial engine will work just fine.
AS the small sailboat burn of .5gph , and only a hundred hours a year , a Roto tiller geared Honda will be fine.
One big advantage of Do It yourself is a commercial transmission (like a Twin Disc) is no harder to install from scratch than a Hurth or other short life Yachtie unit.
FF
Marinizing Small Industrial Diesels Diesel Dan DIY Marinizing 32 08-12-2009 03:59 PM
High Speed - Low Speed Small Disp Diesels tranmkp Diesel Engines 18 02-12-2009 06:21 AM
Marinizing a 350 jaydubya999 Gas Engines 9 07-17-2007 07:08 PM
De-Marinizing morbidflorist DIY Marinizing 19 06-06-2006 09:12 AM
reviews of small marine diesels? goBoating Fiberglass and Composite Boat Building 1 05-01-2004 11:14 AM
