| Light Loading Operation Do the electronic diesels mitigate the damage risk from consistent light load operation in comparison to the pre-electronic (mechanical) diesels? I'm certain that there is less fuel to carbon up things but I'm wondering if its really as simple as that. Opinions, please. |
| Its not a "carbon up" issue in my opinion it was always glazing of the cylinders resulting in a poor piston ring seal and a smokey engine. As long as the engine is given a high power output at some time I dont think it does harm. |
| Why do you ask. Are you grossly over-powered? If so, why? Choosing displacement mode over planing? If so, there may not be the economy there that you think there is. That is to say: liters-per-hour versus nautical miles-per-hour. -Tom |
| ...according to my local Cummins reps, they do not glaze like they used to cos the xs fuel is not there to do so
| If light loads really could do harm to a diesel engine, industrial engines would have a shorter life than vehicle engines. But the opposite is true: a vehicle engine designed for 100 hp @ 4000 rpm is offered as a 50 hp @ 2500 rpm industrial engine with a 5 times longer life expectancy and longer service intervals. The only difference is the adjustment of the injection pump. In applications like generators and compressors an engine is running with little or no load at a fixed rpm most of the time and can do that almost indefinitely. I expect the glazing issue to be connected mainly with insufficient operation temperature and large engines running on bunker fuel.
| Have a look down at the docks and see the fishing boats going no where but all lights on,--thats to load the generator 25% is sufficient. Truck drivers leave the engine running while they sleep for the heater as long as next day they haul 40 tons about no harm done. There is no excess fuel in the cylinder or it would fire and RPM increase. Sometime a turbo internal leak can cause an engine to run away simply burning the oil from the turbo. The man asked of carbon build up under light loads. |
I'm sure that the "why" of it will be asked so my use calls for a long haul between port and fishing grounds (this boat will never lobster) and I'm looking for a mid-20s cruise speed. She might also try her hand at the Maine lobsterboat races. Thanks |
| Under loading and its destruction is a problem. National Fisherman ran a 2 part series on it years ago. With your use getting to and from the fish grounds will easily be enough heavy load to make up for the tiny load just fishing. The problem would come if you decided to run at displacement speeds , say to FL. 1200 miles at 6K, perhaps 30 hp required would require preventive measures to slow the underloading hassle. Burning 1.5 or 2 gph in an engine that would normally burn 10-15 gph , can cause the cylinder bores to burnish, blow by to dilute the oil , and if a turboed engine other turbo problems from lack of boost. FF |
| Sail Loading on Rig, Rig Loading on Vessel | brian eiland | Sailboats | 93 | 02-23-2011 07:19 PM |
| Tug-barge operation | monjure | Powerboats | 0 | 11-25-2010 03:33 AM |
| About lifting operation through hatch | wjw_1980 | Boat Design | 0 | 03-28-2010 09:32 AM |
| Current speed for boat operation | Opa | Boat Design | 0 | 02-22-2009 02:59 AM |
| Fishing Vessel Operation | Hamidi | Education | 2 | 08-29-2004 01:29 PM |
