| leak off pipe - Bukh 20 hp engine I have installed a Bukh 20 hp engine which has a leak 0ff pipe with Tee piece. One side of the Tee goes direct into the top of the fuel filter and the other should go to the top of the fuel tank. It is not possible to get into the fuel tank without major restructural work so I'm wondering if it will be ok to just plug off this end of the pipe. If I do so, will this cause any problem???? |
| Peter, This link is to a forum devoted to marine diesels, with several threads on the Bukh. One in particular speaks of fuel injector return lines, which may be what you see on your engine: http://boatdiesel.com/Forums/index.c...N1172621872937 . You have to join that forum to access the threads, but it might be a good source of info for you. Cheers, Charlie |
| leak at seam on keel- new-b | ralphi | Wooden Boat Building and Restoration | 3 | 07-10-2006 11:10 PM |
| leak at seam on keel- new-b | ralphi | Boat Design | 1 | 07-10-2006 09:43 PM |
| Carvel Plank Rowboat Leak Repair | Glennigan | Wooden Boat Building and Restoration | 2 | 05-11-2006 01:28 PM |
| Hull Infusion leak | eckmuhl | Boatbuilding | 4 | 09-17-2005 05:34 AM |
| Bukh DV 7 | Robert Miller | Propulsion | 4 | 01-03-2005 11:37 AM |
