| Kub0ta for DC generator I just bought a brand new Kubota deisel on ebay for $650.00. I already have an extra Balmar 210 amp alternator that according to specs operates at full capacity at 6000 rpm. The engine develops 13 hp at 3600 rpm. The power curve on both taper off slowly at higher rpm. The alternator should draw less than 8 hp. Should I run the engine at lower rpm and use a double pulley on the fly wheel with the ratio to the alternator pulley adjusted accordingly, or run the engine at full rpm with smaller pulleys. I am concerned with both fuel economy and noise, as well as loading the engine appropriately. Thanks in advance for any incite. |
| Some folks have find the throttle units used on welding machines to be excellent at controlling this style gen set. The unit will lower the RPM to as low as it can get , yet still produce the required voltage. This is greaT if YOU ATTEMPT TO 100% CHARGE A BATT SET , AS THAT LAST 10% OR 15% , goes in really slowly . FF |
| Timothy: I'd lean towards setting it up so that maximum alternator output comes with the engine fully loaded. If yours is a 24 V alternator, its peak output of 5 kW will probably come with around 8-9 hp on the input shaft, so about 3/4 of full power for the engine. Without knowing what engine you have and without being able to see its performance curves, a very rough guess would be around 3000 rpm for 3/4 power. Since you're home-brewing anyway, a diesel welder governor such as Fred describes would probably make sense, backing off the engine throttle when full output is not needed (ie. when the alternator's regulator eases off as the batteries approach full charge.)
| Timothy: You probably bought a Balmar series 94 alternator, 210 Amps, 12V. That one will draw approx 6 hp at full output (including belt losses and fan), so you need an industrial belt, multi-V or even better a timing belt. The Kubota can supply the horses at less than 3000 rpm, so choose a ratio of 1:2.2, 2700 rpm for the diesel, 6000 for the alternator.
| wind generator | luso | Marketplace | 0 | 06-18-2008 02:09 PM |
| Marine generator | BustedKnuckle | Electrical Systems | 11 | 11-23-2007 08:01 AM |
| generator installation | Wild Bill | Electrical Systems | 0 | 02-16-2006 07:53 PM |
| wind generator? | trimarandan | Sailboats | 3 | 01-13-2006 09:03 AM |
| Portager's Generator | Portager | Electrical Systems | 0 | 07-24-2003 12:19 AM |
