Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 09-28-2010, 10:14 PM
carlos bairo carlos bairo is offline
Rep: 10 Posts: 41
kool keel diesel engine
hi to all'''''
i like to know if it's better to fit the engine (kubota 28hp diesel) with a
heather exchanger or with out ,i have a kool keel sistem instalation on
my boat,up to 30kw area kooling,
cheers carlos
Old 09-29-2010, 05:32 AM
Rep: 756 Posts: 3,328
The usual reason for keel cooling is to get rid of the second pump and heat exchanger.
Keep your keel cooling , BUT , install a thermostat in the keel cooling circuit to prevent over cooling. This is common on keel coolers as overcooling can be a problem.
FF
Old 09-29-2010, 06:58 PM
Rep: 10 Posts: 41
FF;; thanks for your reply,i belive that i could fit a normal tractor engine and saving
on the exstra cost of a marine engine with heater exchange ,dealers on marine motors
on sydney prefer to sell the complete unit try to persuade my thats the best way to gow luckily to have all your experience people on the forum .
most regards carlos
Old 09-30-2010, 06:03 AM
Just dont "save" on a cheapo transmission.
My suggestion is a Twin Disc , rebuilt ,used from a TD dealer is fine.
Even a low time running takeout is fine.
Avoid Hurth ot Velvit drive
FF
Old 09-30-2010, 12:58 PM
Rep: 1493 Posts: 7,447
A keel cooler is a good idea. A tractor engine not so much. By the time you fit a marine gear and fabricate a custom exhaust it will cost way more than a marinized engine.
Old 09-30-2010, 01:01 PM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
Wouldnt it also have a lower life span and more problems Gonzo due to marine environment?
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
Old 10-01-2010, 05:50 AM
Wouldn't it also have a lower life span and more problems Gonzo due to marine environment?
Nope until you get into the huge sizes of SHIP engines , most "marine" engines are simply tractor or HD truck engines.
With a dry exhaust there is no need for a special wet exhaust manifold , simple insulated covering will keep the engine room temps down (120F max).
FF
Old 10-01-2010, 06:48 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
So just a radiator then will keep it cool enough, is rust due to salt water an issue ? (sorry dont mean to hijack thread!)
Old 10-01-2010, 08:45 AM
apex1
No,
the keel cooler unit will. A car radiator rusts away.
Old 10-01-2010, 08:55 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
http://flagshipmarine.com/keelcool.html
OK got it thx
Old 10-19-2010, 01:36 AM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
What is the downside to keel coolers? Are they damage prone? Do you usually have a raw water backup system? What do you use as coolant?
Old 10-19-2010, 05:44 AM
Most are mounted where if the boat takes the ground on that side , there clear.
Also the mounting spot is worked so travel lift slings cant get it.
Hitting debris the trash is pushed apart bu the bow getting wider, the cooler is usually aft of the max beam of the boat , so out of the debris stream.
No backup is done as the stock water pump , built into the engine is really reliable.
The ability in hard freezing areas (the cooling system fluid is 1/2 antifreeze , like a vehicle) to just walk away at days end is a huge plus.Genuine diesel antifreez (not Prestone) is used to extend the engine life.
Although a bucket is sometimes tossed over the exit of the dry exhaust.
My preference is for a muffler setup that is REALLY quiet , and doesn't require the pail.
Look at "Hospital Critical" exhaust systems used in standby gen sets for the idea.
FF
Old 10-20-2010, 11:20 PM
Rep: 10 Posts: 41
FRED do i need a heater exchange on a kool keel beta marine engine,
(kubota) 22hp the kooling area will take up to 30kw engine,it look to my thats
is similar to the car kooling sistem witout the radiator just the kooling voids
at the keel.please i need some info about the instalation with dry exhaust,
best regards carlos
Old 10-21-2010, 05:54 AM
www.waltergear.com
Here is an old company that has been creating keel coolers "forever".There are others .
What is the dry exhaust question?
FF
Old 10-21-2010, 06:55 AM
apex1
best regards carlos
The keel cooling unit is the heat exchanger, what else would you need?
The exhaust duct has to be heavily insulated to avoid burning your boat, thats it in principle. (really heavy)
Regards
Richard
How to design a diesel engine? arvi DIY Marinizing 14 12-15-2011 01:19 PM
diesel engine mounts muzboat Powerboats 4 03-28-2009 09:48 AM
Diesel engine preservation FAST FRED Diesel Engines 2 12-15-2006 07:51 PM
diesel engine ferryman mietchan Diesel Engines 1 06-15-2005 09:18 AM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 03:06 AM
