Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 11-17-2010, 06:02 AM
Rep: 756 Posts: 3,328
Thermostats don't work so fast it would cause such problems.
Come to Florida , you can have a ride on our 6-71 powered 50 ft US Navy Utility , converted to a cruiser.
The engine runs 180F (two new thermostats) and when the pair open the water drips to 160 , and in 4 or 5 min its back to 180.
We are in Florida , the water temp is usually over 60F , the keel cooler is 2 lengths of 1 1/2 water pipe 21 ft long .
Yes over cooling IS a problem. And a bypass thermostat is one solution.
FF
Old 11-17-2010, 08:31 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
Maybe 20F lower temp for few minutes is problem for you but that's nothing.. Drill a bit bigger hole on the thermostate plates (hole that allows a bit circ to cooler when the thermostate is closed).. problem solved.
BR Teddy
Old 11-17-2010, 11:52 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
OR... tandem your thermostats for higher flow rate...
You may want to try staggering the opening temps: one higher than the other, I don't know...
-Tom
Old 11-28-2010, 05:00 PM
sbmar.com sbmar.com is offline
Rep: 26 Posts: 11
No formulas, just past experience on a typical 15 K's boat with a 300 HP diesel-- 40 ft of 2" galvanized pipe has no issues keeping the engine right at the 180 F thermostat level in 60F water under varied operating conditions.... Never used the vessel as a tug or push boat (WOT with zero head way), but that's a different set set of calcs.. Maybe 50-100% more pipe??
Tony
Tony Athens / Seaboard Marine
Old 11-28-2010, 06:32 PM
singleprop singleprop is offline
Rep: 10 Posts: 48
I used John Deere Document AG-24 to calculate the length. I think it is quite conservative (no extra padding needed) and I came up with a total of 150 feet of 3.5" half pipes divided into 3 pipes of 25 feet on each side of the keel..for a 160 HP engine!
It seem a lot but if JD are using these numbers then I can too......
The document is quite specific with input data such as pump flow, heat rejection numbers (BTU/MIN), number of half pipes, boat speed, pipe size.
If anyone has the document can they help me confirm that my calculations are correct, based on a 160 HP engine, 5100 BTU/min, 6 kts and 3 parallel paths???
I think that I will arrange each run with a manual shut-off valve so that I can finetune the flow to keep the keel cooler return temperature around 20 degree lower.
keel cooling microlyn DIY Marinizing 8 11-21-2008 06:12 AM
Keel cooling pipes microlyn DIY Marinizing 1 11-17-2008 03:01 PM
converting from fresh water cooling to keel cooling Big H Buck Diesel Engines 9 07-06-2008 06:02 PM
Keel cooling martinwill Inboards 2 06-19-2007 03:13 AM
Cooling System yasky Powerboats 13 05-14-2006 02:36 AM
