| Isuzu 2.8TID marinize help hello, every body, I am grant from comfort diesel power limited. currently we are develop our Isuzu 2.8 TDI engine for marine, I have got a heat exchanger from Bowman, now I need comments for the impeller pump. could anyone give me some comments? For which model of the sea water pump I should use, or some specification for the water pump? I have just finished our conversion for cummins 4 and 6 cylinder engines, 130-350HP engine. they are successful, because you always request the low height engines. If you interested, can veiw our link www.comfortdiesel.com ![]() |
Did you look at my photos ? They show all the marine conversion I did on the 4JB1-TC engine. I machined an alloy adapter plate to bolt to the front lower pulley ( end of crankshaft ) and bolted the Jabsco pump to the alloy plate. I used the 1" Jabsco pump from my old engine, 5.0 litre V8. I think Bowman suggest that a 3/4" pump is OK, but my 1" one works well, and gives plenty of cooling water for the intercooler. I did keep the standard Isuzu oil cooler on the engine, this is cooled by the internal engine water, and does not cool the oil enough. I am going to fit a marine type oil cooler in the circuit from the Jabsco pump, as this colder water will cool the oil better. I am happy to help with any other questions you have. Do you possibly have a power output curve diagram for this engine, as I am trying to work out the best gear ratio and propeller size ? Regards, Paul |
| Thanks Paul for your help, so now you are using 1" impeller pump from Bowman? If you have the photo for the pump, could you send me one? I want to check with the installing. my email is info@comfortdiesel.com. regards |
| I am pretty sure that the 2.8l 200hp CMD diesel is the Isuzu 2.8. Check what the specification sheets say their pump is. |
| hi, ali, for Isuzu 2.8 TDI engine, we have already build it out, the output is 98HP, the CMD engine you are talking about is diesel or gasoline type? |
| Hi I have currently got the Izusu 4jg2 engine which i have marinised this is coupled to a mercruiser alpha 1 gen 2 leg, This to has the bowman watercooled manifold but the raw water is voir a 3/4 inch bsp jabsco mounted where the power steering pump used to be. If this is any help to you. |
| Marinize a Subaru? | curtis73 | DIY Marinizing | 20 | 05-14-2012 01:35 AM |
| What engine to marinize | MengWalton | DIY Marinizing | 18 | 08-17-2011 11:44 AM |
| To marinize or not to marinize that is the question | treeclimber@xtr | DIY Marinizing | 7 | 04-20-2008 03:59 AM |
| Isuzu C240 | thom wessels | Diesel Engines | 14 | 07-10-2007 08:06 PM |
| Why Marinize | briggsy | DIY Marinizing | 11 | 03-16-2006 02:51 AM |
