Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 10-09-2011, 01:53 PM
Paul F Paul F is offline
Rep: 10 Posts: 21
Injection Pump Govenor
Hi All,
Can anyone please explain how the GOVENOR part of the injection pump works, and what it does to control the engine ?
Regards, Paul
Old 10-09-2011, 02:47 PM
Rep: 1493 Posts: 7,447
It controls fuel flow to keep RPM's constant. Mechanical systems work with centrifugal weights, electronic systems work with a sensor.
Old 10-09-2011, 02:52 PM
Rep: 10 Posts: 21
Thanks Gonzo, so does the " throttle " leaver increase fuel flow or does it control speed of the govenor.
Old 10-09-2011, 02:55 PM
It controls the governor. Think of it as a cruise control in a car.
Old 10-09-2011, 03:00 PM
Rep: 10 Posts: 21
That's obviously why it is easier to maintain constant RPM in a diesel engine when compared to a petrol, particularly with a carb.
Old 10-09-2011, 03:06 PM
Rep: 670 Posts: 2,457
The govenor also keep a diesel engine from running out of control.
Old 10-09-2011, 03:14 PM
Rep: 10 Posts: 21
Ah, so it controls and LIMITS the RPM, hence the name " govenor " to govern the revs.
Thanks, I'm learning more. I'm just trying to make sure that with proper use my engine will give me many hours / years service.
Regards, Paul
Old 10-10-2011, 05:49 AM
Rep: 756 Posts: 3,328
There are two types of units .
One will attempt to keep the RPM the operator set.
The other limits the HP (fuel flow) to the set point and will allow the RPM to drop under load.
Old 10-10-2011, 05:54 AM
Yes indeed...two types, functions for a govenor. One chokes off fuel supply, the other regulates it.
Old 10-11-2011, 09:48 PM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
Not quite there are constant speed governers - gen sets etc
and variable speed like cars trucks and propulsion engines
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 10-11-2011, 09:56 PM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
Where does one find a variable speed governor for a Yanmar 3YM30 engine?
That would be the type that you set at say, 1800 RPM to run a generator.
Kurt Hughes was right about this place.
Old 10-11-2011, 10:08 PM
gen set needs a constant speed governer
EDIT ones that holds the engine at a constant speed
Old 10-11-2011, 10:26 PM
No....
Link
"The variable speed mechanical governor is found extensively on industrial and marine applications, since it is designed for the following functions:
Controls the engine idle speed
Controls the maximum engine speed hydraulic-type governors (industrial and generator sets)
Holds the engine speed at any position between idle and maximum as desired and set by the operator."
Any idea where to buy one for a Yanmar 3YM30?
Old 10-11-2011, 10:43 PM
ok its a terminology thing
you buy a variable speed governor to hold the engine at constant speed with very little droop
and a constant speed supplies constant fuel supply so load increases and the engine slows down
my bad
Old 10-11-2011, 10:45 PM
Originally Posted by CatBuilder View Post
No....
Link
If its internal jerk pump style then it would be yanmar, its its external inline or rotary you could speak with the pump manufacturer
so how about we just say you want a governor with only a few percent droop
Looks like the Yam has en external inline pump so start with the pump manufacturer
3 prong oil pressure switch and electric fuel pump, is a fuel pump relay needed? sdowney717 Powerboats 1 09-28-2011 07:20 AM
Fuel injection pump, a unexpected problem. CDK Diesel Engines 9 07-07-2011 02:03 AM
Injection pump starting device CDK Diesel Engines 3 05-08-2008 05:40 AM
Perkins 4236 injection pump the ucf Diesel Engines 0 02-12-2008 04:37 PM
(sold) SULZER 40/48 injection pump assembly BRAND NEW Micom Diesel Marketplace 0 08-07-2006 06:28 AM
