Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 04-19-2008, 11:34 AM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 526
Hurth HBW 10-2R in pieces on my bench
I am not a mechanic!
My transmission had been underwater and it was rusted solid. I took it apart and cleaned all the rusty mud out of it and finally got all 4 bearings spinning freely. Besides new gaskets what else would you recommend I do before I put it back together. If it requires parts who do you recommend? (I have no clue how to take the Bearings off if that is a recommendation. )
This paragraph is written two hours later: I guess I'm not done. I tried a dry refit to see if I remembered how to put it together. It went together OK, but the gears are in a lock position. The only way I can describe it is that it seems to be in forward and reverse at the same time. I can move the center track that changes the gears, but nothing happens. Am I supposed to be able to see a change? Do I have to take the whole assembly apart? Be gentle. I'm not a mechanic
Gluing vertical pieces crosscut Wooden Boat Building and Restoration 15 03-10-2008 01:24 PM
How to fillet corner of two intersecting pieces Grant Nelson Software 1 09-13-2006 03:39 AM
apolstry and custom back bench work redleg2424 Fiberglass and Composite Boat Building 2 04-25-2006 11:38 AM
Need Hurth transmission Psuedomonas Marketplace 0 08-24-2005 01:48 PM
full bench boat seats bobboudignon Materials 2 12-01-2001 11:59 PM
