| How much will the C of G change? I have a 36 ft trawler with twin diesels. I'm changing transmissions and the new output shaft has a two inch drop from the old transmission ouput shaft centerline. This means I have to raise the engines two inches. Does anyone know if that is a minor adjustment or a major adjustment to the boats center of gravity. Obviously the longitudinal c/g goes up verticaly on the boat. Is two inches too much for a 36 ft long, 14 ft wide 10 ton boat? |
| What's the weight of the two engines? One ton? Maybe the cg will rise 1/2 inch? I don't think that is major. It depends on the weight of the engines. |
| C of G They are turbo'd in line 6 cylinders so I have to believe they weigh around 1,200 to 1,400 lbs each. |
| I agree it is good that you are thinking about this but a couple of inches either way is not going to affect anything also how much heavier are the transmissions that you are putting in over the orignals ? Frank L |
| The engines are maybe 15% of the total weight, so my guess is that two inches up isn't a major change. |
| Center of Gravity The new transmissions are about 100lbs which is about 33 lbs heavier than the old ones. The boat is nose heavy though so a little more weight behind the moment point is no problem. |
| My concern would be to make sure you have enough holding the engines to the stringers cause the trans weight will and is going to help you. I think when putting the new engine mounts make sure you extend the mount down not the stringer up to the mount cause then I think you could have a problem and extend the mounting surface of the mount maybe an extra bolt so it has more surface area to transfer the pressure to Just some food for thought Frank |
| Somebody Please help with impeller change! | SC Hartwell | Outboards | 2 | 01-14-2007 01:44 PM |
| Change My Skeg? | mcody2005 | Boat Design | 1 | 11-06-2006 12:45 AM |
| How to change the Alternater belt? | Art | Outboards | 4 | 09-15-2006 11:39 AM |
| How about a change of pace? | Handtool | Fiberglass and Composite Boat Building | 11 | 09-14-2006 09:42 AM |
| Career Change | preaser | Education | 2 | 10-07-2004 11:29 AM |
