Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 01-06-2011, 11:08 AM
Downtown Downtown is offline
Rep: 10 Posts: 13
How Fast Can I Go?
Another newbie question. I have a 1982 44' Marine Trader I'm restoring. 14.4 beam. Displacement is about 33,000 lbs. I pulled the FL 120's as they were toast. Replacing the black iron fuel tanks with aluminum. I am putting in 1992 Volvo TAMD 41Bs, taken from a charter boat with 1200 hours. These engines are turbo charged and are rated at about 200 hp. I plan to use the BW trannies that were on the Lehmans.
What would you imagine my fuel burn to be at various speeds? Top speed?
Old 01-06-2011, 02:54 PM
Carteret Carteret is offline
Rep: 122 Posts: 106
Boatdiesel.com has excellant calculation software. Membership is @ $25. Well worth the investment. The forums alone are worth the membership.
Old 01-06-2011, 03:52 PM
Rep: 10 Posts: 13
I am am member and went in. The calculator is saying that I can only go 8.5 kts, using 69.4 shp. This is standard speed for trawlers with FL 120s. I thought with the 210 hp of the Volvos, I could get up to 12 kts.
Old 01-06-2011, 07:36 PM
Pierre R Pierre R is offline
Rep: 458 Posts: 461
Oh you will probably get around 14-15 knots or so wide open throttle burning around 22 gallons an hour. At 12 knots you will probably burn around 12-14 gallons an hour. Thats a rough guess. Its not the most efficient hull to push up towards planing. It depends on the props and how you have it loaded. I am not sure how the boat will handle either. It may handle poorly.
Old 01-06-2011, 08:12 PM
Rep: 122 Posts: 106
Perhaps you might want to consider buying a planing hull vessel.
Old 01-07-2011, 06:38 AM
Rep: 10 Posts: 13
Just want to know with the Volvos if I have to get up to 14-15 to run out a storm or in an emergency, I can.
Old 01-07-2011, 07:31 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
With 33000 lb of weight I sincerely doubt you'll manage to arrive at 14 kts with just 200 HP.
The maximum speed you can get, imho, will be 10-10.5 kts. Propeller cavitation will probably be the biggest speed-limiting factor, even if you double the engine power.
Cheers!
Old 01-09-2011, 06:23 AM
Rep: 458 Posts: 461
daiquiri my answer was for 400 hp. The Marine Trader has fairly flat buttock lines at the stern.
Old 01-09-2011, 09:02 AM
Rep: 756 Posts: 3,328
There is also the question of weather the tranny will hold up, and weather the shafts will be too small.
Remember the boat was planned as a 6 -8 cruiser burning 4 -5 GPH and was built as required.
FF
Old 01-09-2011, 06:11 PM
Rep: 10 Posts: 13
Fred,
So, if I put the Volvos in with the current set-up, I should just go slow?
Old 01-09-2011, 07:47 PM
El Sea El Sea is offline
Rep: 36 Posts: 55
Downtown,
If your main concern is to out run a storm - I would recommend that you build your seamanship skills and adapt to the sea. I have a 44' Thompson with a single DD 4-53 and have never tried to out run a storm. Fourty-four foot trawlers were not made for speed, they were build for cruising. Take the time to build those skills and choose the right weather window.
El Sea/L.C.
"Suckin Sludge & Havin a Gas"
Old 01-09-2011, 09:22 PM
Rep: 10 Posts: 13
El Sea, you found me out. Truth be told, I like going a little faster than 8 knots. Just for fun.
Old 01-10-2011, 06:25 AM
You can use many books to check on weather the tranny and shaft size are up to the new HP.
The problem you may end up with is a boat that needs to be used outside , not suitable for the ICW .
Diesels are not at all like gasoline engines where reducing the load makes them last longer.
Diesels are designed to operate at a load , at least a load on a turboed engine where the turbo is actually working.
Most industrial engines love 80% load at 90% rated RPM.
Truck engine omarinizations will run at lower power ratings as they seldom climb hills all day long.
But once you get below a point , say 20% of rated output or less , for very long , the engine efficiency and service life DROPS!
Your boat was built to run with 2 fairly weak engines at 30-60hp output each , about 2 1/2 to 4 GPH . IF the turbo required the engine output to be above this range , just to show a positive boost , you will be tossing 6-8 ft waves at folks docks.
Underloading can be a problem with diesels , not with gas.
Underloading is a slow death . so if you only run say 200 hours a year it will take a decade or more to start the slobbering.And every time you get outside a half hour at high load will be a big help at cleaning out the carbon.
FF
Old 01-10-2011, 08:53 AM
Rep: 10 Posts: 13
Thanks, Fred.
How fast will it go? Mark Emaus Propulsion 36 03-13-2009 08:43 AM
SPEED as in FAST Manie B Open Discussion: All Things Boats & Boating 8 08-31-2008 04:34 AM
Fast Launch 26 Pericles Powerboats 29 02-27-2008 01:22 PM
no go fast stuckinslowmo Propulsion 7 11-20-2006 04:06 AM
fast boats Gena Sailboats 6 05-04-2004 09:49 PM
