#46
| Carteret, I'm not looking for someone else's cheap headache. I don't want a diesel guzzling monster with a "possible bent rod" and the potential cornucopia of other headaches that usually come with a boat of that vintage. I don't want a planing hull, because a planing hull in the length range I want will use a lot of fuel. I also mentioned "trailerable"; that boat you found is either in a slip at Tommy's Marina or behind a house with a dock, neither of which I care to pay for. Again, the goal is a trailerable, seaworthy hull design that can be driven economically, in the size range of 20 - 24', that I will build. I've presented a few ideas and welcome others. |
#47
| Homefront. The boat I referenced in my post was an example, not intended to be a remedy. I just happen to agree with Richard about second hand boats. If you really desire to build, look to what the comercial fisherman in your area are using. I spent many an hour in the Gulf Stream off the coast of North Carolina. I learned that safety, stability, and comfort are crucial. Even if you plan to fish within sight of land and are comitted to building. It is better to enjoy a day of fishing than having to endure it. Since economical, low powered, and trailerable are your parameters, I would look to the New England style lobster boats. |
#48
| http://www.stormportboatworks.com/mo...asicspecs.html Check this out , it could be the start of what you need. FF |
#49
| Good boats Fred, I agree. |
#50
| Carteret, I catch your drift... the things you mention are high priorities. Fred, I like the suggestion. That Oyster Cracker looks a lot like Atkin's Rescue Minor. I started this thread questioning the suitability of a small motor I found, if it were installed in Atkin's Sallie Hyde, another hull with the Seabright upright garboard but without the tunnel. We seem to be the right track. ![]() |
| FLUENT - How difficult is to use it? | Panos_na | Software | 2 | 09-15-2009 12:30 PM |
| Convert Twins To Single Engine? | seo | Sterndrives | 4 | 07-25-2009 11:48 AM |
| Difficult project (for me) aluminum foil (3.5 cmx 3,5 cm) needs to hold up a penny | jephman | Boat Design | 5 | 11-19-2005 07:19 AM |
| What's the best automotive engine to convert | Adz | DIY Marinizing | 6 | 08-16-2005 09:01 AM |
| Difficult To Find Book | ADRIAN77 | Propulsion | 0 | 11-10-2004 12:49 PM |
