#31
And having done it that way, you would have some 150 lbs or so saved above WL, then a sandwich made house would be within technical possibilities. Due to the fact that there is no Atkin left to revise the plans, who will do that? I do´nt feel comfortable without. Did I understand the post above right? The engine is´nt available any longer? Regards Richard
__________________ Fortior est qui se quam qui fortissima vincit Moenia. |
#32
| The engine is available - TowmanDoug was suggesting an even less expensive alternative - a Perkins - which is, sadly, out of stock. As for stability; after the boat itself was built, I would do a mock up of the center console/enclosure to simulate the height and weight and do some sea trials before I built the real thing. Another thing to consider: Atkin provides 2 sets of lines with the plans - one hull designed for 9-10 knots, the other for up to 16 knots. I assume that the faster hull has less upsweep to the chines aft, providing more bearing and bottom for prop thrust so she doesn't dig a hole. This has me wondering if the faster hull would also provide more initial and reserve stability. Methinks it's time to order the plans and find out! |
#33
| Nothing can beat a empirical test.................... Due to your engine choice (and economy), there will be only one choice left, which one to build!? What was it 55$ or so. I think that is a good and relatively cheap start. Regards Richard
#34
| Better hull choices? Perhaps either of these two would be more reasonable for the power: Devlin Dipper. I would lengthen this hull 2-3' for more fishing space, which I think would also be necessary for an inboard installation: http://www.devlinboat.com/dipper.htm Atkin Surprise. I might add 1' to this one, and move the low cabin forward 2'. Then I could add windshield to the aft edge of the low cabin, with some kind of foldable bimini: http://www.boat-links.com/Atkinco/Sail/Surprise.html |
#35
| The Dipper looks nice and sturdy, but is too short of course. But lengthening is a new design. It is not just adding a few inches, unfortunately. The Atkins would not need much to change, but a modern building method is again a new design either. Maybe just look further! I would do so too, but I´m a bit short in time, have just today adopted a new project. Regards Richard
| FLUENT - How difficult is to use it? | Panos_na | Software | 2 | 09-15-2009 01:30 PM |
| Convert Twins To Single Engine? | seo | Sterndrives | 4 | 07-25-2009 12:48 PM |
| Difficult project (for me) aluminum foil (3.5 cmx 3,5 cm) needs to hold up a penny | jephman | Boat Design | 5 | 11-19-2005 08:19 AM |
| What's the best automotive engine to convert | Adz | DIY Marinizing | 6 | 08-16-2005 10:01 AM |
| Difficult To Find Book | ADRIAN77 | Propulsion | 0 | 11-10-2004 01:49 PM |
