| Have to agree with Jack frost. In my opinion the engine is your most important piece of safety equipment. It will get you out of trouble more often than a life jacket! There will always be an occasion when you wish you had more power. My Macwester 27 had a 12hp Yanmar engine when I bought her. After a season of sailing I change to a 20hp Nanni. (Kubota based unit) Beautiful little engine. Much more like the power I felt comfortable with. My next boat is a 37' steel Shadow. It comes with a 20hp engine. Joke! That's getting up graded to 40-50 hp before she even hits the water! |
| Engine manufacturers do say today that no break in is required due to the machining tolerances that are extermely accurate. I dont agree,-- breaking in 'bedding of the rings' is important on a new engine. After that not so important. It is certainly not such an issue as to carefully choose a used engine that has exactly the right power requirments. |
| Jack, the deal is that they are using rings that are already polished when installed and they final hone the cylinders to a 600 grit finish. There really is no break-in; it was done on the honing machine and at the piston ring factory. But if it makes you feel good to do some kind of a 'break-in', go ahead, it won't hurt anything. It can be a sort of ritual like breaking a champagne bottle over the bow ![]() Jimbo |
| Jimbo--600 grit???-- I used to use 80,-- I usually use 600 to polish automatic transmission valves, or brake cylinders. Evan plasma coated rings ( new types ) need bedding--initially. |
| Yeah 600 grit! The last two engines I built spec'ed a 600 grit final hone and the instructions that came with the ring set said flatly no break-in was necessary. I heard Click and Clack recently say that all the auto makers are using basically the same type rings. Probably cuts down on a lot of warranty and arguments with the service dept. By the time they drive it from the production line to the car carriers it's broke in ![]() Jimbo |
| Alik hello! i thing you talk portuguese... e o seguinte: tenho planos de 2 dos seus barcos, o "Pilgrim 590" e do "Kavalier 800" queria construir em prencipio o primeiro. mas de onde tirei os planos nao esta em portugues.pedia que me ajuda-se em algumas questoes, pois nem sei, por exemplo do material e premenores de construção da quilha, por exemplo. gostaria que me ajuda-se.. obrigado abraço |
| Alik axo que falas portugues. tenho planos de dois dos teus barcos . mas de onde os tirei nao estava em portugues. gostaria que me desses uma ajuda, pois tenciono construir um deles. em prencipio o de 5,9 metros. obrigado pela atençao despendida fica o meu e-mail: sky_walker_x@hotmail.com abraço |
If you are near Langkawi - send me a email I will direct you to a yachtsman who is changing engines - good price . |
#25
| Witch carb to choose: 450 or 600 CFM??? | Pevito2 | Gas Engines | 4 | 07-27-2007 08:45 AM |
| Is NPL 3797 series suitable for 32 knot passenger catamaran monohull? | swaroopmadhavan | Boat Design | 2 | 08-06-2006 12:52 PM |
| woods to choose from | Redsky | Materials | 11 | 08-05-2006 08:52 PM |
| Is NPL 3797 series suitable for 32 knot passenger catamaran monohull? | swaroopmadhavan | Multihulls | 0 | 08-02-2006 01:23 PM |
| what type of yacht to choose | kadik | Open Discussion: All Things Boats & Boating | 10 | 11-20-2004 04:09 PM |
