Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
  #91
Old 06-11-2010, 05:00 PM
apex1
Originally Posted by piperca View Post
Richard, that was might thought. My only concern is that I've never worked with the chemicals mentioned and believe there is a trick behind using them. I'm led to believe that improper application can lead to corrosion issues, so I am researching this to make sure I am not headed for disaster.
Has anyone worked with Alumiprep 33 and Alodine? What might be the complications of an improper application? What, if any, are the tricks to applying these chemicals?
When you follow the application rules / schemes, provided by the supplier / manufacturer, it is no black magic to get a perfect surface. Then again do as the coating mfg tells you in the application manual and tataaa.. it works.
Apply a double coat of primer before you build up the Ep tar or whatever coat you have in mind. A single coat primer is insufficient! (I apply three primer coats of 50µ)
The main prob with all these materials is, that the homebuilder (and some self proclaimed Professionals) try to cut corners and apply insufficient methods and / or materials to save some pennies.
Btw. Armaflex AF is the foam you should use, when you use foam!
Regards
Richard
  #92
Old 06-11-2010, 08:07 PM
M-Sasha
Single Diesel.
Sasha
  #93
Old 06-11-2010, 08:08 PM
piperca piperca is offline
Rep: 21 Posts: 70
Thank you, very informative!
While pondering, I did think of an alternative that might keep Mark happy (no foam, LOL).
If I were to make saddles/straps that are about 3-4 inches wide and made of 1/4" stock. The saddles/straps would follow the contour of the tank and attach to the top of the stringers using bolts ... something like this:
I would line the saddles/straps with 1/4" starboard (blue area in drawing), dadoed out to 1/8", to overlay on the saddle/strap to isolate it from the tank. The tank would be suspended by the saddles/straps off the hull of the boat. Tabs made of angle, welded to the sides of the tank, would secure the tanks to the tops of the stringers. I was thinking 3 of these saddles/straps would be adequate along the length of the tank (36").
What do you think? Would the aluminum saddle/strap be strong enough to support approximately 700lbs (tank plus contents)?
Twin V6 to single diesel conversion burt2 Propulsion 21 02-01-2011 07:00 PM
Twin inboard gas to single diesel conversion goodidea28 Diesel Engines 1 09-06-2006 11:48 PM
twin single keel Garth Boat Design 5 08-18-2006 05:21 PM
Twin diesel / generator / single shaft prop setup SeaSpark Propulsion 2 04-22-2006 02:47 PM
Decision of the Shaft Center Line position in Twin Screwed Boats Donald Boat Design 0 03-29-2004 07:52 PM
