Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 01-03-2007, 04:31 PM
darrenledniczky darrenledniczky is offline
heatexchanger
hi i'm daz i'm building a 20'ft fishing boat i've got a 309 diesel engine,would it be any good for the boat,
Old 01-04-2007, 12:10 AM
StianM's Avatar
StianM StianM is offline
Rep: 114 Posts: 577
That was limited information
Old 02-18-2007, 04:43 AM
billythefish billythefish is offline
heatexchanger
hi I am building a 24ft aluminium sport type fishing boat I have a alpha 1 gen 2 outdrive and I am going to use an isuzu 2.8 td diesel engine , I am going to make a stainless steel heatexchanger and run a sealed system on the engine and the pump in the leg to run water through the heat exchanger.what size is your boat, what drive are you using
Old 02-18-2007, 06:32 PM
sal's Dad sal's Dad is offline
Atkin/Bolger fan
Rep: 80 Posts: 109
Building an aluminum Diesel, why use a heat exchanger? Why not an integral keel cooler, welded on the inside of the bottom? Or do you need cooling for the outdrive?
Sal's Dad
Old 01-06-2008, 09:57 AM
leomagill leomagill is offline
Rep: 10 Posts: 3
If thats a peugeot 309 you are referring to have a look at www.leomagill.co.uk and go to the 'project puggit' button, lots of marinising pics.
