| hand starting cranking I am sailing a 27 ft with a 1gm10 yanmar diesel that can be started with a hand crank ... it has saved me on a number of occasions with dead batteries and once with a bad solenoid. I am now building a 32 ft sailboat and want a diesel in the 25-30 hp range ... are there any diesels out there in that range that can be hand started? thanks for the help |
| Bukh is one for sure, yhere are still others
| The old Volvo MD series can be hand started but Volvo parts are priced INSANELY!! Google Lifeboat starting motors , there use starters that run on Hydraulic pressure , a bit pri$y , but a good reason to install a Hyd windlass , that never stops when the "white smoke" escapes from an electric jobbie. Hyd pressure if lost can be replaced with a hand pump in a short time , and if your LAZY sheet winches can usually be hyd operated too. You tail, as it turns , and you pressurize later ,after the tacking duel. FF |
| The Yanmar BTD engines are also still handcranking. http://www.yanmar.com.au/marine/btd_...btd_series.htm
| LEFT and RIGHT HAND rotation | inventing_man | Jet Drives | 9 | 07-05-2007 03:47 PM |
| Winches. 2nd hand | Mychael | Open Discussion: All Things Boats & Boating | 0 | 03-19-2007 05:47 PM |
| mercruiser 170 224 slow cranking | crackerjack | Sterndrives | 2 | 02-28-2007 04:28 PM |
| RTM VS. Hand lay-up | Kovaceski | Fiberglass and Composite Boat Building | 24 | 12-17-2006 10:34 PM |
| Second Hand Software | guest12020101217 | Software | 1 | 09-12-2003 09:34 PM |
