Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 05-28-2010, 07:37 PM
girvin girvin is offline
Rep: 37 Posts: 73
Gph
If a full displacement trawler burns 5.5 GPH @ 8knts is there a formula for it a 7knt or 6? 50ft lwl 14.5 beam DD 8v 71
Thanks!
Old 05-28-2010, 07:39 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
No, too many variables for any formula to be accurate. The engine manufactures fuel flow chart should give some indication, but you will need to know the rpm at 8 knots to be able to even start interpolation.
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
Thanks!
from your engine graph,
then for every 50shp approx 2 imp gals per hour
Old 05-28-2010, 07:50 PM
Rep: 37 Posts: 73
Thanks guys I will find out the rpm. I am just trying to see if this will be a good boat for a passagemaker conversion.
Old 05-28-2010, 07:54 PM
Previous Member
Rep: 0 Posts: 0
oh heck just saw 8v 71, double that!!
you should look, for an engine , that will get you i nautical mpg,
betterr to repower with something like a John Deere Whilst I was with Cummins we had an 8v71 on the dyno with a 903 cummins, lugged back the 8 v was using twice the fuel
Old 05-28-2010, 09:26 PM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
Hard to believe one could push a 50+ foot boat at 5.5 gph w a DD 8-71. But if your numbers are correct The burn at 7 knots should be about 4.5 and at 6 knots about 3gph. That is IF the boats doing 5.5 at 8 knots. The DD should make about 15hp per gallon so that would indicate a power loading of about 75hp at 8 knots. Put that way it sounds more reasonable. The boat manufacturer should have a graph/curve that should show how much power is required to push the boat in question at a given speed. If you can give me the displacement I could approximate power requirements by comparing to some known boat/engine examples
Easy Rider
Old 05-28-2010, 09:57 PM
Rep: 37 Posts: 73
Well it was designed for trolling/light crabbing so its a fairly efficient hull. I will try to find the displacement its not my boat just looking at it. Ocean producer under fishing @ pacificboatbrokers.com Its not my first choice but its local and they might want to trade for my sailboat. I was on a 47 a couple of days ago burning 2.5 gph @ 7nts he had a gardner. I want his boat.
Old 05-28-2010, 10:10 PM
jonr jonr is offline
Rep: 34 Posts: 246
I take it that measuring it is out of the question?
Old 05-29-2010, 12:05 AM
Rep: 37 Posts: 73
if you mean the fuel burn I will if I get to a sea trial. I was just seeing if I could figure it out I know it drops alot with speed.
Old 05-29-2010, 05:10 AM
Rep: 756 Posts: 3,328
A 50 ft lwl should run 7K with ease ,
Depending on the weight and loads most long range cruising is at .9 to 1.15 of the Sq Rt LWL, 7 in your case.
Frequently a 1k reduction will lower the fuel burn by 20% .
Detroit's work best when loaded , so you may find the boat does better with a "cruising prop, where more diameter (or pitch if there is no room for a bigger prop) will allow higher loads at lower RPM.
As low as 1200rpm is OK for long range cruise , nice and quiet with great low fuel flow IF loaded.
FF
Old 05-29-2010, 10:15 AM
Easy Rider's Avatar
Rep: 694 Posts: 670
I was hoping you'd weigh in here FF. Do you think grivin's burn number could be correct? Gardner ..YES. There was a 58' boat on a brokers site .. Pacific someth'in or other. Looked like an old freighter.
It looks like (from my references) 40 - 50 continuous hp should be required for the kind of hull I think we're talking about. Three to 5hp per ton.
Easy Rider
Old 05-29-2010, 11:09 AM
Rep: 37 Posts: 73
So with a 20% reduction I would be burning 4gph @ 7nts I guess that would not be good enough. Would repowering with a 671 make a big difference? O want to get down to 2.5 -3 gph @ 7knts I have been on boats that do it but maybe they had a more efficient hull shape. I was going to buy a 45 troller with a gardner when my boat sells but these guys might be interested in a trade.
Old 05-29-2010, 11:36 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
Ocean Producer on Pacific Boat Brokers has a 325HP Lugger.......The Gardner will have the lowest specific fuel burn (gallons per HP hour) and the Jimmy the highest......
There's a lot more that goes into buying a boat than just the fuel burn....If you can get a boat that's perfect structurally for a low price then changing the engine becomes attractive and possible. If you can get a boat that's less than perfect but already has a Gardner installed then that's more attractive....Personally I think hull shape and structural condition are far more important than the current engine.....
But you haven't said what your use is for this vessel.....if you are living aboard and cruising BC/Alaska then fuel consumption probably doesn't matter as much as initial cost and structural integrity. If you are planing round the world voyages then face the fact that you need to either buy or install a Gardner...
Ocean Producer here.....http://www.pacificboatbrokers.com/de...e_Number=LW379
This boat would be the shape you want for ocean cruising.......http://www.pacificboatbrokers.com/de..._Number=NW2484
Old 05-29-2010, 11:43 AM
Rep: 37 Posts: 73
Thanks tad I got the engine confused on 2 different boats. Yes my wife and I are planning to cruise down to south pac and hopefully circumnavigate one day. They boat will be full time live aboard and a surf exploration vessel I might be working out partial sponsership by taking some pro surfers to different spots here and there. I have just trying to get a idea about this boat bc they are considering a trade for my sailboat. Which has been difulcult to sell. It has been very well maintained and is a local boat everyone seems to think highly of it. I like the halibut schooner but 195k for a beat up work boat thats ridiculous. It gets the same burn as the producer. I know the foward cabin isnot Ideal but I am quite restricted on how we do this.
Old 05-29-2010, 12:41 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Well one person's beat up workboat is another guy's immaculate yacht......
Have a look at the engine room pictures of Fearless...compare with the engine room pictures of Ocean Producer....if you are able to deal with this mess yourself, perhaps the boat makes sense...if you have to hire someone???? Before heading for the south seas I'd be looking at totally gutting the ER of the Ocean Producer....it's a typical fishboat in which every system is haywired together.....It's all got to come out and be replaced with new reliable stuff...that will be very expensive and doesn't begin to address the structural problems you will find when you tear out the foam and glass in the hold.
And asking price has almost nothing to do with selling price these days......
