Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 05-20-2009, 05:02 PM
toveri toveri is offline
Rep: 10 Posts: 4
Gen-set for a Pilot-boat.
Can anyone give an advice for to install a small gen-set in an aluminun 36 ft.
Pilot-boat, which is powered with 2 Detroit-Diesel engines 175 KW each and there is no other power source available except for the batteries.
The intention to install the gen-set it's to supply energy for a 3/4 ton Air Cond. unit in the boat's cabin, average weather temps. are above 85 F. and in summer time it goes to 120 F.
Thank You in advance for any suggestion can anyone supply.
Old 05-20-2009, 05:25 PM
rasorinc rasorinc is online now
Rep: 678 Posts: 1,129
Google Subaru/Robin. They make a smaller diesel unit you could build in if vented correctly. Do not know the price but this brand makes quality engines.
Old 05-21-2009, 06:57 AM
Rep: 700 Posts: 3,208
If you wish to do without the gen set and still have air cond its EZ , but not cheap.
A big bus usually has a 250-300A /24V alternator , and with a 4000W Trace inverter , you could run a pair of air cond , only while underway.
Far less maint than an extra diesel noisemaker ,
FF
Old 05-21-2009, 12:52 PM
Rep: 10 Posts: 4
Thank You for the tip.
Old 05-21-2009, 12:54 PM
Rep: 10 Posts: 4
Good advice, I will look forward for your suggestions.
Classic 53ft. Pilot house project boat 4-sale LiveAboardBill Marketplace 3 06-21-2009 12:28 PM
pilot boat cfr Powerboats 9 04-01-2009 06:34 AM
mercruiser alpha one gen 2 won't start steve3211 Sterndrives 4 04-04-2008 03:30 AM
Mercruiser Alpha Gen II Gear Ratio Help CreoleIII Sterndrives 4 06-01-2006 12:14 AM
Set of CD's of Wooden Boat Kleine kapitein Marketplace 0 02-19-2005 09:27 PM
