Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 10-07-2007, 08:37 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 431 Posts: 1,008
Fuel injection pump, a unexpected problem.
I am in the process of converting two 1,9TD engines (from VW T4 vans) for a second life as boat engines, but encounter an electrical problem wiring the injection pump.
I once used a similar but much older engine for a power generator. The injection pump had a red wire hanging out that was connected to a solenoid. With 12 volts on it, the valve opened and the engine could be started.
But on these newer engines where I expected the fuel solenoid to be, there are two wires coming out, both with > 50K resistance to ground and/or each other. A solenoid should be 100 Ohms or less, so there must be something else in the black plastic box attached to the fuel pump.
According to the car's circuit diagram, the brown wire is connected to the ignition switch and the green one goes to the immobilizer unit that 'feels' the presence of the proper car key.
Can anybody tell me what signals must be applied to these leads to get the pump doing what it is there for? Just putting 12 V on them is not correct. The pump draws 15 mA for about a second, than falls back to about 5 mA. Both values are far to small to open a fuel valve.
On the other hand it cannot be very complicated because the rest of the engine it 100% mechanical.
Old 10-07-2007, 11:02 PM
Rep: 445 Posts: 765
Sounds like probably a digital logic circuit. It probably waits for a digital 'key' to tell it to turn on a solenoid. See if you can refit with the older style solenoid. Can you get the harnesses and keys that came with the engines?
Jimbo
Old 10-08-2007, 02:55 AM
CDK's Avatar
CDK CDK is offline
To make tampering with the circuit a bit harder, they attached the device ("fuel valve controller" they call it) with 2 exotic screws that lost their heads in the fastening process, so you need a chisel to remove it. And not before the whole pump has been removed from the engine.
The engines were salvaged from damaged cars together with some other usable parts, the rest disappeared in a giant hydraulic press and will be reincarnated by now. What I will do if nobody with detailed knowledge comes forward is buy a new immobilizer unit and hook up to an oscilloscope to find out what the signal looks like.
As I said, except for this circuit the engine is purely mechanical. A can imagine a circuit that responds only to a digitized version of Germany's national anthem, but in this case it probably just will be a pulse of a certain length, a pulse train or even a fixed frequency.
Old 10-08-2007, 06:10 PM
Rep: 445 Posts: 765
Since it is a security device, it could be looking for a digital 'word' of a certain number of bits, keyed to that particular car. That is why I asked if you could still come up with the harnesses. Let's hope it doesn't work that way
Old 10-08-2007, 08:16 PM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 225 Posts: 569
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
CDK, eventually that box puts power on the fuel solenoid, right??
Once you grind off the screws and open the box, the solenoid coil contacts should be seen, I think... Trash the rest??
Regards, Terry King ...On the Red Sea at KAUST
Old 10-08-2007, 09:29 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 989 Posts: 4,515
How does the repair shop phase and calibrate the pump? They must know.
Old 10-09-2007, 12:32 PM
CDK's Avatar
CDK CDK is offline
You are quite right. There is no VW-Audi dealer on the island, so I put a friend at work who lives in "civilization". He just sent me a picture of an identical engine with the black box removed. Under the hood there is the solenoid waiting I've been looking for, with about 2" wire already attached. Problem solved!
For pump overhaul and adjustment there is an electronic box that simulates an immobilized that sniffs the proper key. For sale only within the dealer network of course.
Thanks for your contributions.
Old 10-11-2007, 10:57 AM
CDK's Avatar
CDK CDK is offline
Attached is a picture of the innards I removed from the pump. It seems like is really needs a lot of digital code to enable the fuel valve. A 22-pins chip with lots of parts on both sides of the circuit board, quite a weird part for a mechanical injection pump. Once removed, the solenoid is freely accessible.
carby or fuel injection ajbale Sterndrives 15 06-22-2007 12:20 AM
carby or fuel injection ajbale Sterndrives 1 05-22-2007 07:33 AM
lt1 fuel injection 02 sensors? duc748 Gas Engines 1 08-18-2006 03:29 PM
SULZER 40/48 injection pump assembly BRAND NEW Micom Diesel Marketplace 0 08-07-2006 06:28 AM
Fuel Injection? LKJR Propulsion 0 07-14-2004 05:31 PM
