Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 08-16-2008, 03:17 PM
brian eiland's Avatar
Rep: 1503 Posts: 2,648
Fuel Coolers on Comman Rail Engines
Are fuel cooling devices necessarily required on common rail engines??
Quote from a friend;
"I had serious fuel overheating problems to the extent that all 4 of my Racors melted! Had a diesel mechanic knowledgeable about common rail fix the system in Key West - he said he had never seen a common rail without fuel coolers on the return nor fuel pumps on the input side of Racors."
Old 08-18-2008, 06:56 AM
Rep: 700 Posts: 3,207
As your friend noticed the block adds to the heat of being compressed to 20,000 - 30,000 psi or more, and coolers are required.
The large class 8 trucks ("18" wheelers) with similar electronic controlled engines now install air removers as the fuel gets very agitated as it travels the engine and returns to the fuel tank.FF
Toe rail curvature Roly Wooden Boat Building and Restoration 13 03-20-2008 08:32 AM
Painting under rub rail? mtnrat Fiberglass and Composite Boat Building 0 06-09-2007 10:34 AM
Aluminum Toe Rail JC47 Materials 2 02-09-2006 12:39 AM
rub rail replacement prettygoodguy11 Sailboats 1 09-23-2005 08:56 PM
Spray rail design nevd Boat Design 9 05-06-2004 07:50 PM
