Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 11-14-2009, 02:54 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
Engine Zincs
My Yanmars have at least 3 engine zincs that would be eaten away every 6 months. They are not cheap to replace and there are so many with different threads,---- and if you can unscrew the zinc from the 22mm plug.
For 3 years now I have always flushed with fresh water after use, I think I have given this enough time now to post that 90% of zinc erosion has stopped with fresh flushing.
I know people flush outboards but I dont know of anyone fresh flushing sea going engines after use.
Old 11-14-2009, 04:13 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,692
I always used to fresh water flush my old small outboard on my fishing boat after every trip.
Old 11-30-2009, 12:57 PM
powerabout powerabout is offline
Rep: 432 Posts: 1,358
Be very careful about leaving fresh water in an engine IF there is any part like the exhaust that is stainless in the raw water circuit.
The zinc will become the noble part and the stainless the anode.
In freshwater use the zincs are replaced with ( I think) magnesiums ones but for sure not zinc.
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 06-13-2010, 05:54 AM
WickedGood
Yanmar 240 HP
I just bought a brand new boat with Yanmar 240 HP in it
My boat has a garden hose fitting to do fresh water flushes after using in salt
The Model # on the Engine is RCD6LY2x1
Cant find a Service manual anywhere. would you know about them?
where are the zincs?
Pictures?
also Having trouble finding Fuel Filters Yanmar/Racor Part # 4412-012
Any of you folks have a good source?
Capt Walt
WickedGoodOutdoors@maine.rr.com
Old 06-13-2010, 06:22 AM
capt littlelegs capt littlelegs is offline
Rep: -67 Posts: 237
Pictures?
Capt Walt
There shouldn't be any need for zincs in the engine itself if the engine is cooled through a heat exchanger and it should be unless very small. There might well be zincs in the sea water parts.
You dealer or builder should supply this info.
Old 06-13-2010, 06:57 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,145
Pictures?
Capt Walt
The engine designation is 6LY2, what the rest means is unclear to me.
There are not less than 5 Zinc anodes to control corrosion in various cooler parts.
This is a page with some details:
http://www.yanmar.com.au/qrg/6ly2-ste.pdf
I hope that helps.
rgds
CDK
Old 06-13-2010, 07:03 AM
WickedGood
Close.
The engine in my boat is an Inline 4 cylinder
RCD6LY2x1
It also have a second metal tag that has 4LHA-STP
Old 06-13-2010, 07:29 AM
CDK's Avatar
CDK CDK is offline
These Yanmar numbers are sometimes confusing, but if the factory has put that tag on it they were sure it was a 6 cylinder.
To get certainty, make a picture and compare that with those on http://www.yanmar.com.au/marine.htm or their US counterpart.
The LY2 series are not listed on the Yanmar site anymore, but they have the new BY2 series instead, where the B stands for BMW!
Old 06-13-2010, 07:55 AM
WickedGood
Old 06-13-2010, 08:55 AM
CDK's Avatar
CDK CDK is offline
Yes that is the right one!
240 hp @ 3300 rpm for stern drive use.
Yanmar says this is 4LHA-STZP; you won't have any problems finding the info now.
Good luck!
Old 06-16-2010, 06:34 AM
WickedGood
Are Yanmars SAE or Metric?
Putting together a tool kit for the boat.
I also have lots of extra tools for sale. ended up with a couple sets from my Grandfather, a couple sets from my Father and I already have a few sets myself so Im thinning the heard.
tools for sale.
Open End Wrenches: Various sets
Socket Sets 1/4", 3/8", 1/2" in a tool box $100 for all
Spin Socket Driver Sets $20 per set
Tin Snip Sets $20 per set of 3
a couple table saws $100 each
a 12" Delta Planer & Metal Cabinet Stand $200
Stanley Hand Planes $200 Each
Lots of other stuff.
Old 06-16-2010, 07:43 AM
CDK's Avatar
CDK CDK is offline
I guess they're metric, at least since they cut a deal with BMW.
No kidding, the Japanese have always been metric unless they made special products for the US market, but do things a bit differently. An M8 bolt has a 13 mm head in Europe, 12 mm in Japan (better steel!). You probably need Torxx as well, that is becoming popular very rapidly.
Old 06-17-2010, 06:34 PM
Bglad Bglad is offline
Rep: 67 Posts: 156
I don't buy that on the basis you are saying. Zinc is -1050 in the galvanic series, stainless -150 when it is passive (oxygenated) and still only -550 when active (oxygen starved) way more noble than zinc in either case. What is possible is if the zinc sits in freshwater it may form corrosion and insulate itself so it no longer functions properly but I doubt that would be the case with clean tap water.
Vetus electronic engine remote controll, and setting starbord engine do conter clockw omnitrips.com OnBoard Electronics & Controls 11 06-21-2009 02:43 AM
blisters around zincs on steel boat lfrancis Materials 7 08-31-2008 10:20 PM
From a V-? engine to a 4 cyl.... building the front engine pad sikpupy Fiberglass and Composite Boat Building 0 06-10-2008 09:39 PM
Perkins T6.354 Zincs Jstclair Diesel Engines 1 04-04-2007 04:20 PM
140 mercruser engine c.i.d. identificafion by engine serial number ggsimpson Gas Engines 0 11-18-2006 11:39 AM
