Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 08-14-2011, 09:03 PM
whitepointer23 whitepointer23 is offline
Rep: 247 Posts: 655
Originally Posted by Katoh View Post
Fast Fred
I was told prior to purchase of the vessel that it uses a mere 7ltrs/hour@ 20knots
I cannot confirm that figure but it sounds mighty low to me.
Cheers
Katoh
it won't be far off, we put one in a 21 ft glass boat and it uses almost nothing at speeds up to 23 knots.
brendan .
Old 08-15-2011, 07:08 AM
Katoh Katoh is offline
Rep: 58 Posts: 196
Ok! that figure must be in the ballpark then. you would think with that sort of economy, you surly could not be loading the motor much at all.
While on the subject of the volvo motor, I realise this is a slight deviation from the initial question. I plan to re-paint the motor after removing all the the rust, I want to repaint it with a 2K epoxy paint. I figure that because of the raw water system, temperatures in the engine bay would be nothing like that they are in a car/truck motor. there would be no use to use high temp engine enamel, were an epoxy in the marine environment is so much better. the added bonus is that I already have the paint.
Cheers
Katoh
old Volvo engine PZNR help needed topcat1000 Inboards 2 07-03-2009 06:24 AM
Question re Volvo engine lostatsea Sterndrives 1 08-07-2008 02:53 PM
Engine block for 4.3L Volvo zomowiec Powerboats 4 06-02-2007 05:42 PM
Correct stern drive for Volvo engine cnoel1 Sterndrives 1 05-04-2006 08:45 AM
Volvo engine problems cnoel1 Propulsion 5 03-29-2006 02:21 AM
