Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 11-01-2006, 04:33 AM
bcervelo bcervelo is offline
Rep: 10 Posts: 27
engine beds for Beta JD3
Can anyone recommend a type of timber for mounting this engine on, the timber will be bolted to steel and the engine bolted to the timber.
Old 11-28-2006, 09:14 AM
QC3 QC3 is offline
Rep: 10 Posts: 5
I am not an expert in this area, but I would be inclined to use oak, pre-drilled and then coated or sealed on all sides and ends and drill holes with epoxy. I would probably also want to lay down some sort of moisture separation (like tar paper or similar) between the oak and the steel so that condensation does not build up under the oak notwithstanding the fact that it has been pre-sealed. Again, the expert boastbuilders out there may have a differnt view, but that is how I would handle it. Just my seat-of-the-pants opinion...
Old 01-21-2007, 01:05 PM
Black Swan 01 Black Swan 01 is offline
Rep: 10 Posts: 10
A good close-grain old growth Douglas Fir. High density, good rot resistance, easy to pressure or immersion treat with wood preservative, very strong shear strength, good machinability.
Old 04-12-2007, 04:19 PM
trisailing trisailing is offline
Rep: 10 Posts: 7
If your boat is fiberglass, make a solid fiberglass L shaped engine mount then Glass it to the hull. I just made some for my boat and can upload a picture of them. They are about 1/2 " thick. They replace the same kind that where there for a previous engine, then there is no wood in the bilge to rot. The old beds where there for 40 years and I had to use a sawzall to cut them out. Then you can bolt your mounts to it and not use lag screws. Bolt is easier to replace if it breaks.
Free Beta software for "surfacing" CGN Software 6 08-02-2006 06:56 AM
Looking for BETA test users marcb Software 4 03-20-2006 12:49 PM
Replacing an outboard engine with an inboard engine boere Sailboats 1 09-16-2005 08:49 AM
automotive engine -> marine engine???? mechanical314 Boat Design 2 08-02-2004 09:47 AM
Replacing an outboard engine with an inboard engine boere Boatbuilding 0 06-23-2003 05:21 AM
