Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 10-09-2011, 12:23 PM
nevilleh nevilleh is offline
Rep: 53 Posts: 65
engine air intake
Hi all,
Just a simple question about engine room vent intakes.
The rule of thumb used to be 1 square inch per 1 horsepower.
Can anyone tell me if this is correct and what manufacturers require?
This would bethe vent area cut in deck / hatches for inboard diesel engines.
Thanks
Neville
Old 10-09-2011, 12:47 PM
Rep: 670 Posts: 2,457
This document contains a general discussion of engine room venting.
Be aware that on a boat you may have other considerations... air breathing generator or additional heat generating machinery like battery charger or inverter banks installed in the engine room so be conservative when specing your system
http://www.gregorypoole.com/products...ENTILATION.pdf
Old 10-09-2011, 12:48 PM
Rep: 1493 Posts: 7,447
It's half square inch per HP for diesels.
Old 10-09-2011, 12:53 PM
Rep: 53 Posts: 65
Hi Gonzo,
Thanks, that makes me feel better, I guess I should get it in writing from the manufacturers . Just had a few tales from fishermen that were getting me worried.
Regards
Neville
Old 10-09-2011, 01:02 PM
Rep: 53 Posts: 65
Michael,
Thanks for that. The document suggests that it may be worthwhile for us to consider forced ventilation as I am aware that our cramped engine rooms together with fairly large fast revving engine are quite hot relying on only natural draft ventilation from the apertures in the deck hatches above.
More investigation needed!
Regards
Neville, Scotland
Old 10-09-2011, 01:13 PM
If its a simple boat...use simple solutions.
If the machine room is more complex, get your fingers working and research available documents on the web.
Heat is destructive to machine room equipment. Plenty of fresh air when under operation and at rest is needed. Good circulation of this air in the machine room is important.
Old 10-09-2011, 02:01 PM
Paul F Paul F is offline
Rep: 10 Posts: 21
Thanks for that link Michael, it's luck that my son just got his degree in maths to help me understand it !!
Paul
Old 10-09-2011, 02:56 PM
The half inch formula is for air intake. Ventilation to keep the engineroom cool may need more .
Engine room Air Intake/ Ventilation rich99uk Inboards 19 09-30-2011 06:53 PM
The Jet (air) Engine kach22i Propulsion 0 11-30-2007 01:41 PM
Intake Side Skirts T Mac Outboards 0 11-01-2007 04:24 PM
AQ225 intake manifold fisherken1 Gas Engines 2 10-17-2007 09:15 PM
"HRV" Air to Air exchanger for ventilation? ldrumond Boat Design 5 12-09-2006 08:51 PM
